Old 05-23-2008, 02:08 PM   #1
nicku
nicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enough
noob question about timing gun
Hey guys
I am thinking to check my timing with timing gun. I have redtop SR.
I have searched a lot of threads. and everybody says connect a spark plug wire to my spark plug and the other side connect to the coilpack. and connect the timing gun to the spark plug wire.
now my question is, how do you connect the spark plug wire to the coilpack? They are both female ends, right? so how do I connect it right?
nicku is offline   Reply With Quote
Old 05-23-2008, 07:12 PM   #2
slider2828
slider2828's Avatar
Get a real timing gun. Matco, MAC Tools, Snapon, and even cheap ones you borrow from Autozone basically has a round hook that you just slide onto your coilpack wires. THe other clamp goes to the negative of your battery.... That is it....
That is the setup.... Get a picture of a timing gun first instead of what other people say especially on forums.
Turn and Burn!
Old 05-23-2008, 07:17 PM   #3
burnsauto
burnsauto's Avatar
yeah... let the engine warm up, unplug the tps, and then you're ready to set the timing.
Old 05-23-2008, 07:19 PM   #4
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 05-24-2008, 02:14 AM   #5
nicku
my friend's got a timing gun, however, he said it is used for the spark plug wires car. and he is not sure if it can just work on the coilpack cars.
It has battery posts and spark plug wire connector and a timing degree adjustment. Do you guys think I can just use that one?
Old 05-24-2008, 02:49 AM   #6
NI_YON_Zenki
NI_YON_Zenki's Avatar
NI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud ofNI_YON_Zenki has much to be proud of
I love Dilla 2! oh my goodness! hawtness! but yeah, theres no such thing as a real timing gun, just real assertiveness at timing.
Best regards.
"GHOST"
NI_YON_Zenki is offline   Reply With Quote
Old 05-24-2008, 02:50 AM   #7
S14DB
AFC #1
S14DB's Avatar
On the coil pack harness by the firewall you will find a loop of wire hanging out. Clip the pickup to that.
Old 05-24-2008, 03:21 AM   #8
nicku
do you have a picture of it? I am sorry but it will be really helpful.
thanks in advance
Old 05-24-2008, 11:52 AM   #9
superaudi
superaudi's Avatar
superaudi is an unknown quantity at this point
i tried the loop of the wire on the coilpack harness by the firewall and tried to connect witht he coilpack 1 wires, too. But the light doesnt work. I hook up the gun to an jumper because i have my battery in the back. Does it matter? or what did i do wrong?
superaudi is offline   Reply With Quote
Old 05-24-2008, 12:00 PM   #10
slider2828
slider2828's Avatar
I hooked it right next to the coilpack #1 wires, and the neg. It just needs to be grounded, the gun gets positive from the coil pack when it fires... Just find good ground on your car.
Turn and Burn!
Old 05-24-2008, 01:47 PM   #11
nicku
got it worked...thanks a lot guys
Old 05-25-2008, 01:13 AM   #12
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
on some sr's the loop in the back reads differently than just clipping all 3 wires that go to coilpack 1. shitty autozone timing lights won't read by clipping the 3 wires going to the coil pack, but my timing light does and is right everytime that way. if i take it and clip the black loop, sometimes it's different, sometimes it's not. but i've never had a problem setting base timing by clipping the 3 wires going to the coil pack.
fwiw just my .02
Dave =]
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
