Old 05-23-2008, 05:48 PM   #1
green_s13
green_s13 is an unknown quantity at this point
Q: Off Alignment
Hi everyone, I just install my Greddy Type S coilover, drop it low and camber. and Now my car's alignment is off to the LEFT. so is the a special degree or number i need to know to get my car alignment by Tire Plus. Any suggestion, please help me out. Thank U.
green_s13 is offline   Reply With Quote
Old 05-23-2008, 05:50 PM   #2
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
are you running adjustable after-market arms?
WheelsDirty
Old 05-23-2008, 05:52 PM   #3
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
If you just take it to a normal alignment shop and pay for a normal alignment they will just align it as close to factory specs as possible. Are you looking for the factory specs? The alignment shop will have access to those numbers. Are you looking for reccomended custom alignment specs? If so we need to know what you want to use the car for as the alignment will differ depending on the application.
Old 05-23-2008, 06:00 PM   #4
green_s13
everythin is stock. Only my coilover is aftermarket. so i need to let my local alignment shop to align it to factory spec??
Old 05-23-2008, 06:05 PM   #5
racepar1
racepar1's Avatar
If you just wanna drive around town and are not really interested in track/autocross or drift then yes just get the factory specs. If you get really into track or drift you can always get it re-aligned. The factory specs will satisfy 90% of drivers. Keep in mind that unless you have adjustable arms they will not be able to get it back to factory and probably not even close to factory specs.
EDIT: Since you still have 100% stock suspension basically all they can do is set the front end up to stock (if your coils have camber plates) and set the rear close enough to drive straight.
Old 05-30-2008, 01:34 AM   #6
4bangers
4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices
I'm in the same boat, what is the best specs for daily and some drift/track? thanks
4bangers is offline   Reply With Quote
Old 05-30-2008, 01:38 AM   #7
white92_s13
white92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nicewhite92_s13 is just really nice
rear toe 0, rear camber depends on what you want 1 degree is good to not wear out tires on the street and be fine on the track.
up front i like a slight bit of toe in and about 2 degree of camber. i noticed it keeps the front end going straighter on the freeway keeps it solid.
caster depends, slight bit more caster then stock is good.
white92_s13 is offline   Reply With Quote
Old 05-30-2008, 03:14 PM   #8
Forge_55b
Forge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enough
i would do what white says but maybe a little less camber in the front just for tire longevity but then you could just do 0 camber all around with 0 toe, for theoretically, the best tire life and people would make fun of you cause your car doesn't look "cool" with 0 camber lol
and i just realized that you don't have aftermarket arms so you will just hope to get as close as possible to factory specs and MAKE SURE they get close to the same specs on both sides (left and right)
Forge_55b is offline   Reply With Quote
Old 05-30-2008, 08:08 PM   #9
alkemyst
alkemyst's Avatar
alkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nicealkemyst is just really nice
Send a message via AIM to alkemyst
I found the following S14 alignment specs recommended from whiteline with a kit they sell:
Touring:
Front:
Camber: -1.5 deg
Caster: L+7.5/R+7.0 deg
Toe: 0.0mm
Rear:
Camber: -1.0 deg
Caster: n/a
Toe: 1mm in
Sport:
Front:
Camber: -2.0 deg
Toe: 0.0mm
Rear:
Camber: -1.25 deg
Caster: n/a
Toe: 0.5mm in
Factory:
Front:
Camber: -1.50 to 0.0 deg (-0.75 deg nominal)
Caster: 6.00 - 7.50 deg (6.75 deg nominal)
Toe: 1.5 - 3.5 mm in, (2.5 mm in nominal)
Rear:
Camber: -1.67 to -0.67 deg (-1.17 deg nominal)
Caster: not adjustable
Toe: 0.0 - 5.0 mm in, (2.5 mm in nominal)
Doing this job I saw the chassis flex, right at the cowl/windshield to engine bay...I want to give SPLPart's front fender braces a try definitely...just don't want to deal with fender pulling now and the paint touching up required.
November 15, 2004: I went with this alignment recommendation:
Front:
Camber: -2.0 deg
Toe: 0.0mm
Rear:
Camber: -1.25 deg
Caster: n/a
Toe: 0.5mm in
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master.
alkemyst is offline   Reply With Quote
Old 05-30-2008, 08:26 PM   #10
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
i am in the same boat. i am figuring on have everything set as close to factory as possible but then run about -2 degrees of camber all the way around.
idahotuner is offline   Reply With Quote
Old 05-30-2008, 08:30 PM   #11
4bangers
I have adjustable arms front/rear so I can do any specs that's good, so I guess -2/-1 F/R camber and +8.5 caster
how come whiteline recommend different caster for L/R?
