Old 06-08-2008, 04:52 PM   #1
driver11324
driver11324's Avatar
driver11324 is an unknown quantity at this point
Idle and Vac problem SR
I know that the vacuum should be at 20 in.Hg at idle, but with my car its around 10 in.Hg. I do have cams, but they aren't anything too aggressive (264 in/ex step 1). Sometimes the vacuum goes below 10 in.Hg during idle. The only time I see 20 in.Hg is after I give it throttle and the RPM's go 1200-1400 then it drops to idle and so does the vacuum. It never really bothered me until the other night and now the problem is just annoying me. I am going to do a boost leak check in a little, but are there any other things that I should check?
driver11324 is offline   Reply With Quote
Old 06-10-2008, 07:51 PM   #2
Ninjabread
Ninjabread's Avatar
Hmm I have the same issue with my car, same cams but step 2, and my vacuum at idle sits close to 10 all the time...
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 06-10-2008, 09:26 PM   #3
driver11324
I did a boost leak test and found that my MBC was leaking, so I ordered an AEM Truboost. Hopefully that will fix some of it.
Old 06-10-2008, 09:28 PM   #4
Ninjabread
Ninjabread's Avatar
Oh ok good to know!
I'll try looking for vac leaks on mine too.
613DriftWerks.ca
