Old 06-09-2008, 09:56 PM   #1
Full-Lock
Full-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfection
Send a message via AIM to Full-Lock
WTB new rb25det trans clutch slave cylinder
anyone got one?
interchangeable with any other nissans?
i need the 2 bolt holes under the cylinder side by side
only clutch slave cylinders i can find are the ones that have a bolt hole on top, then actual cylinder, then another bolt hold on the bottom.
thansk!!
Full-Lock is offline   Reply With Quote
Old 06-10-2008, 08:02 AM   #2
SleeperSx
SleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choicesSleeperSx has made poor choices
NAPA Part # 37487
Only 16$ I think total, Works Perfect, I run this slave on a Twin plate Cusco Exedy clutch, So you should not have any problems.
When you get the slave you will have to Drill the 2 bolt holes out to a accept a bigger bolt. But that takes 5 mins LOL.
SleeperSx is offline   Reply With Quote
Old 06-10-2008, 08:14 AM   #3
SleeperSx
This is the difference.
Old 06-10-2008, 09:10 AM   #4
Full-Lock
thanks a lot. ill be doing this today.
i take it the one on the right is the new slave from napa?
after i drill out the holes a bit everything lines up on the housing then? the mounting holes on the napa slave look further apart.
Old 06-11-2008, 05:50 AM   #5
SleeperSx
Ya the one on the right is the Napa slave. Everything lined right up on mine. Just don't tighten the slave down too hard or you will bust the ears off it. I already done 1 like that. But its a simple swap.
Old 06-11-2008, 10:34 AM   #6
Full-Lock
yea alright cool. ordered it yesterday since it was out o fstock at napa in town here. should be here today sometime
thanks again
Old 06-14-2008, 06:55 AM   #7
SleeperSx
no problem, any more questions just let me know.
Old 06-14-2008, 11:39 AM   #8
imotion s14
imotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to beholdimotion s14 is a splendid one to behold
tsc tsc too late but for future reference..
http://www.nismoparts.com/catalog/?section=824#1726
imotion s14 is offline   Reply With Quote
