Old 12-13-2001, 09:18 AM   #1
Guest
Posts: n/a
ok now ive emailed tire rack where i bought my eibach pro kit springs from about this.
it seems on my 240 it didnt drop sh*t except for a lil in the rear. i even compared my car to s13/s14girls car whne she had her s13 and hers was sitting a lil bit lower in the front
has anyone else had problems with this setup, do you think they sent me the wrong springs?
my buddy installed the same setup on his b14 se-r and its perfect! just how i wanted mine.
i have pics of my car stock and now on my webpage didnt feel like slowing down the topic so if you want check it out on my site under nissan car pics.
thanks
Old 12-13-2001, 09:45 AM   #2
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
it usually takes a while for your springs to settle. now if it's been a while, i don't know
whateverjames is offline   Reply With Quote
Old 12-13-2001, 10:22 AM   #3
DSC
New Title
DSC is an unknown quantity at this point
I dono, Eibach says their springs don't settle any lower over time.
DSC is offline   Reply With Quote
Old 12-13-2001, 11:04 AM   #4
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
It is minimal, but you will get a little settling in...mine settled 1/4-1/2" over the course of the month after installation.  The ProKits aren't lowrider springs, though, so don't expect a massive drop from them.  They're engineered for performance, not looks.
So far, I have nothing but praise for my ProKits and AGX's.
LanceS13 is offline   Reply With Quote
Old 12-13-2001, 05:05 PM   #5
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
A lot of people don't notice the lowering asthetically, but have you felt any difference in handling? If you got the pro-kit, that's what you should be looking for, otherwise you ordered the wrong springs.
transient is offline   Reply With Quote
Old 12-13-2001, 05:07 PM   #6
Zenki Two40
Zenki Two40 is an unknown quantity at this point
but still, the sportlines ain't gonna give u terrible handling performance n what not.
Zenki Two40 is offline   Reply With Quote
Old 12-13-2001, 09:11 PM   #7
Guest
Posts: n/a
as far as settling in its been a good month now probably . but still it hasnt even lowered there is still the huge wheel gap compared from front to rear like all stock nissan cars. as i said my buddy got the same setup on his b14 se-r and his is lowered and the wheel gap is evened out.which was what i was shooting for mainly with a nice drop nothin low rider-ish.
handling is great but my front has a big time clanking noise at first on the driver side front. which was due to one spring not sitting correct. which i fixed at work now i just have to look at it with another tech and see whats going on.
did anyone trim there bump stops?
anyone got pics of it on there s13 with this setup?
Old 12-14-2001, 12:17 AM   #8
tristarx
tristarx is an unknown quantity at this point
if the picture of your S13 with the rims is when you have the AGX , Prokit installed, I have to say the wheel gap in the fron tis way too high.
Something is not right, you might want to redo the spring install and make sure it's sitting correctly in the right coil position.
Tx.
tristarx is offline   Reply With Quote
Old 12-14-2001, 09:03 PM   #9
Guest
Posts: n/a
yes with the rims is with my springs and struts in place. they are set in there correct. i've had other techs look at them at work. i might pull everything off tomorrow and take a look and call tire rack since they don't email me back.
either i got the wrong springs or struts but something is not right and its def not the way they are mounted in there.
Old 12-14-2001, 10:37 PM   #10
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
Hey, camppain!
Remember that I had 15" rims and you had 17". That could very well make a difference.
S13Grl is offline   Reply With Quote
Old 12-14-2001, 10:44 PM   #11
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
probably not helping at all since i don't remember the outcome:
a long while ago i remember someone getting eibach springs and the car not dropping at all. he called up eibach and the parts numbers matched. i think it turned out to be a defective pair.... but i'm not sure. i would say give eibach a call. it's worth a shot.
Edit: I forgot to mention that only one pair of springs wasn't dropping for that guy either.
(Edited by AceInHole at 10:47 pm on Dec. 14, 2001)
AceInHole is offline   Reply With Quote
Old 12-15-2001, 03:02 AM   #12
Guest
Posts: n/a
yeah irena i know bout the rim size but the wheel gap shoulda evened out in the front which it didnt.
thanks ace for that info i will be giving eibach a call afterwards hopefully i'll here from tire rack first then also make sure bout my struts.
