Old 12-07-2002, 10:53 AM   #1
nissmo240sx
nissmo240sx is an unknown quantity at this point
Here is what it does: It seems to only boost and respond normally when the car is on the freeway. wierd?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>? Driving around the streets, it usually wont respond. Dist cap and rotor replaced as well as coil. everyone is confused. &nbsp;SOmeone said maybe the ignitor in the distributor?
nissmo240sx is offline   Reply With Quote
Old 12-07-2002, 11:27 AM   #2
Nismos14
Nismos14's Avatar
Nismos14 is an unknown quantity at this point
maybe there is an air leak somewhere? not keeping pressure? when the car is moving at higher speeds it may not be an issue because there is enough pressure to keep things closed together, but when there isnt alot of pressure things can spread apart, u might want to check that out?
'97 maxima 5-Spd
Nismos14 is offline   Reply With Quote
Old 12-08-2002, 10:45 AM   #3
InferiorWang
InferiorWang is an unknown quantity at this point
could be a leak. &nbsp;look around at www.vfaq.com. &nbsp;It is a dsm site bur has a part in there on how to make a leak tester if you can find it.
InferiorWang is offline   Reply With Quote
