Old 06-17-2008, 09:41 AM   #1
jarredd
jarredd's Avatar
jarredd will become famous soon enoughjarredd will become famous soon enoughjarredd will become famous soon enough
KA help, engine running like *@#%
Hey guys,
My car was running fine yesterday... Then this morning when i turned it on to go to work it was puttering. Just to give you more detail, it was idling around 500-600rpm, shaking bad, and making a puttering exhaust note. It was really weak too, by that i mean unresponsive and slow to get going.
Any ideas what it is? maybe misfire, bad sparkplug...? Any help is much appreciated...
Thanks,
Jarred D
jarredd is offline   Reply With Quote
Old 06-17-2008, 10:11 AM   #2
1slowS13
1slowS13's Avatar
1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice
you maybe running on 3 cylinders or less.
check if your injectors are pulsing correctly.
also check the ecm for codes.
1slowS13 is offline   Reply With Quote
Old 06-17-2008, 10:17 AM   #3
mifesto
mifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nice
yeah check spark plugs and ecu codes first....
by chance u filled the gas up last nite?
mifesto is offline   Reply With Quote
Old 06-17-2008, 10:33 AM   #4
jarredd
jarredd's Avatar
no... didnt fill up.... i will check the codes and the plugs... thanks...
If thats not it, any other ideas??
could it possibly be a loose vac hose?
Old 06-17-2008, 11:12 AM   #5
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
that happened to me before, one cylinder wasn't firing
pull injector harness one cylinder at a time and record engine rpm change. if there is a cylinder with NO change in RPM, you have narrowed down the cylinder.
WheelsDirty
Old 06-17-2008, 01:26 PM   #6
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
Hey,
I think I have the same problem not sure, my rpm is about 700 bout sometime down to 600 then up... but car dont really shack much. Do you guys think I have the same problem?? Also, see like no power on high speed..
pink godzila is offline   Reply With Quote
Old 06-17-2008, 01:39 PM   #7
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
sounds like a dead cyl, turned out to be 1 bad plug wire
Originally Posted by pink godzila View Post
Hey,
sounds like you have a vac leak somewhere
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 06-18-2008, 11:53 AM   #8
jarredd
jarredd's Avatar
i pulled the plug... it looked decent, not white or oily or broken.... but i replaced it anyway.... still having the same problem... possibly dist cap? or wires???? the wire seems to be firing though.... i hear a ticking from the wire like its firing.....
Old 06-18-2008, 11:57 AM   #9
xsparc
xsparc's Avatar
ticking from the wire is bad.
start it up and pull the wires from the plugs one at a time. the one that doesnt change how its running will be the bad one. it could also be the cap if you have not changed that yet.
Old 06-18-2008, 12:52 PM   #10
jarredd
jarredd's Avatar
What does the ticking mean?
As i pulled plugs 1-3 the car gets really rough, and on the 4th it stays the same. So i am sure it has to be the fourth one. I replaced the plug, no change. When the wire is out, it makes a clicking sound when it is allowed to touch something. when i just hold it, no sound.
any ideas....
Old 06-18-2008, 01:01 PM   #11
xsparc
xsparc's Avatar
its your number 4 plug wire. get a new one.
Old 06-18-2008, 01:14 PM   #12
oskars14kat
oskars14kat's Avatar
oskars14kat is an unknown quantity at this point
also, at night, you can spay alittle bit of water in the spar plug wires and see if there is arching, if you see arching replace that wire and you should be fine. if the wire insolator is weak the water will create a path with less resistance and will arc. its an easy way to check for weak wires
oskars14kat is offline   Reply With Quote
Old 06-18-2008, 01:18 PM   #13
sc ka24e
sc ka24e's Avatar
sc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura aboutsc ka24e has a spectacular aura about
if yur spark plug wiring is sparking when grounding to something it is not yyr wires... if u already changed that spark plug then its going to be yur fuel injector on #4 .. check if it is getting power.. if it is test injector .. mine had a bad ground on the wiring and wouldnt fire an injector... GL hopefully its not a dead cylinder...
sc ka24e is offline   Reply With Quote
Old 06-18-2008, 11:30 PM   #14
jarredd
jarredd's Avatar
damn, just changed all plugs and wires... no difference.
how do i check the injector/injector ground?? hopefully this can be fixed in the next day or so...
also, how can i tell if its a dead cylinder and what can be done to fix?
Old 06-18-2008, 11:40 PM   #15
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
shit that happened to me all the time. 1 of the injectors had a minor short, so i just wiggled them until it ran correct again...
try that.
SexPanda is offline   Reply With Quote
Old 06-18-2008, 11:59 PM   #16
nissan_driver24
nissan_driver24's Avatar
nissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enough
Send a message via AIM to nissan_driver24
rule of thumb when dealing with a misfire like what u're having right now. Check for spark since it's the easiest thing to do first. and since u replaced the wires and plugs and u're still having a problem check ur dist cap maybe it could be damage, you could also check the rotor but most likly its ok since 1 through 3 is still working.
if that's all good then check fuel, since the 1 through 3 cylinders are working properly, then u're getting good fuel pressure now the only thing to do is to check for voltage pulse with a test light or something in that manner even a dmm will work, if you have good voltage pulse then check the injector for continuity i'm not sure what the ohms run for stock 240 injectors but you can check the injector ohms on one of the 1 through 3 injectors to get an idea of what it's supposed to be. if u're not getting the right ohms reading then it's a bad injector.
I think u are having a problem with ur injector being stuck closed but check everything has to do with the number 4 cylinder and ur problem will show itself up.
--240sx Driver Since 2002 to 2013--
nissan_driver24 is offline   Reply With Quote
Old 06-19-2008, 01:11 AM   #17
xsparc
xsparc's Avatar
what they all say. since you changed you wires and the prob is still there, it could be the cap, but most likely an injector prob.
Old 06-19-2008, 08:25 AM   #18
jarredd
jarredd's Avatar
how do i perform these tests.... which wires should i be checking?
Old 06-19-2008, 10:58 AM   #19
xsparc
xsparc's Avatar
first unplug all the injectors and use a multimeter to check the resistance, they should all be the same.. around 14 ohms if i remember right, correct me if im wrong.
next check for a ground on the wiring harness, i dont have a FSM with so you you need to look up that part.
Old 06-19-2008, 11:09 AM   #20
jarredd
jarredd's Avatar
ok... so i checked resistance on the injectors... 1-3 were at 11 ohms.... the 4th one was reading 2.1-3 megOhms... bouncing around....
I dont have a noid light, but gotta pick one up to check pulse. Could it be a bad/dirty injector....
You think clean it or buy a new one?
Old 06-19-2008, 11:14 AM   #21
xsparc
xsparc's Avatar
MegOhms means its burnt out. sounds liek you need a new #4 injector
Old 06-19-2008, 11:33 AM   #22
jarredd
jarredd's Avatar
does anyone know a good place to pick up a new injector? should i get a new set or just one?
Old 06-19-2008, 11:39 AM   #23
xsparc
xsparc's Avatar
first i would see if a friend had one you can drop in to test with before you go buy some. but you can buy just one if you want.
Old 06-19-2008, 01:59 PM   #24
jarredd
jarredd's Avatar
where from? i have only seen sets?
Old 06-19-2008, 02:02 PM   #25
xsparc
xsparc's Avatar
most auto places have them
Old 06-19-2008, 02:12 PM   #26
NismoS13Chuki
NismoS13Chuki's Avatar
NismoS13Chuki is on the path to ruinNismoS13Chuki is on the path to ruin
i cant believe no one recommended this but an easier way to check a injector with out having to unplug this and that is a screwdriver. You just take a long screwdriver place the metal end of it on the back of the injector wrap you hand around the grip in a matter so that you can put you ear up to it and listen to the injector. a good injector will sound like several clicks and you sould be able to hear it very clearly. anything other sounds can indicate a weak injector and no sound indicates a dead injector.
NismoS13Chuki is offline   Reply With Quote
Old 06-19-2008, 02:53 PM   #27
xsparc
xsparc's Avatar
im just used to doing it my way, i always have a multimeter in the car, but good idea... everyone always forgets the old skool ways
Old 06-19-2008, 04:16 PM   #28
jarredd
jarredd's Avatar
thanks!!! I will try that as well!
I truly appreciate everyones help
Old 06-19-2008, 05:41 PM   #29
nissan_driver24
just go to any auto parts store and they will have one... or get one used from the wrecking yard for free ninety-nine... the old screwdriver to ear is a good trick.... but it sucks when sometimes u're not sure if it is because u can hear the other injectors going on the one u're checking... using the dmm is the only way to go to be 100% sure.
Glad u found the problem jarredd and at least it's an easy fix. My maxima was a pain to fix because i had to take off the intake to replace one injector...
Old 06-19-2008, 06:11 PM   #30
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
Lol glad I wasn't the only one thinking of the screwdriver trick. A mechanic told me about thta, but he had a scope...same principle though.
So what was it bad injector?
s13pignose is offline   Reply With Quote
