#7 | |
![]() Join Date: Apr 2004
You need a good oil pressure gauge. You may as well disconnect the stock oil light. |
#8 |
![]() Join Date: Dec 2002
FIX:
Step 1. Unplug your sender wire, its next the the oil filter. Now it will never flash at you again. Now seriously... When you turn the key to the ON position (not START) the light should be on. When you START the car it might stay on for a sec or 2 but then turn off. If it comes on while the car is running... that is very bad.
No... no one stole my interior... its safely in my garage... ![]() |
#9 |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
probably because when you turn on the ignition (engine not running) there's no oil pressure (due to engine not running).
then once u crank it and it fires up, the oil pressure builds and light goes off edit: xsparc beat me |
#10 |
![]() Join Date: Sep 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
You probably need to do routine maintenance.... when was your last oil change? and when was the last time you replace the oil pressure sensor, sparkplugs, filters blah, blah...? After new filter and oil (correct weight). Report back If the problem still persist.
#11 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
It happened to me a while back... Turns out I was low on oil and my oil filter wasn't on very tight. (I hand un-tightened it >:|)
#12 |
The oil level is full, I haven't checked the filter lately however. I'll have to call a friend to get the oil pressure checked. Could someone explain how the pressure is checked? (plug this in to that while this etc.)
#13 |
with a gauge. plugged into the sensor hole right next to the oil filter. if you're getting an aftermaret gauge and sender i see no reason to keep the stock sensor (which only warns you when oil pressure becomes dangerously low)
