Old 06-28-2008, 04:12 PM   #1
mx240sx
mx240sx is an unknown quantity at this point
s15 hlsd
so heres the scenario.. i have a 2jz 240 wich will have a t74...yada yada its gonna put down ovr 700rwhp. i picked up a q45 rear end and hubs just for the gearing...i also ordered a s15 hlsd with shaft. i noticed that the when i took it apart the ring gear has 13mm bolts. took one off my old diff and theyre 12mm bolts. will i still be able to use the s15 lsd...??
mx240sx is offline   Reply With Quote
Old 06-30-2008, 12:23 PM   #2
LigouriRd
LigouriRd's Avatar
LigouriRd will become famous soon enoughLigouriRd will become famous soon enoughLigouriRd will become famous soon enough
Or cut some adapters from copper tubing.
'96 Nissan 240SX KA-T ─ '05 Grand Cherokee Laredo 4x2─'85 Nighthawk
LigouriRd is offline   Reply With Quote
Old 06-30-2008, 12:25 PM   #3
murda-c
murda-c's Avatar
Yeah i think the thread size is the same just the shank is different, so you can make an adapter for them, buy new bolts, or some people just use the 12mm bolts.
I wouldn't do that though..
Old 06-30-2008, 12:27 PM   #4
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
i swapped my s15 hlsd into my open differential and reused the bolts. no problems
idahotuner is offline   Reply With Quote
Old 06-30-2008, 12:28 PM   #5
murda-c
murda-c's Avatar
there you go, just reuse the bolts.
