Old 07-03-2008, 08:51 AM   #1
LibertySyclone
LibertySyclone is making a name for him/her selfLibertySyclone is making a name for him/her selfLibertySyclone is making a name for him/her self
Can ABS be retained with a non typical swap
I am in the middle of my LS1 swap in my 95 240sx and I noticed the ABS is integrated into the engine harness. (as are the wipers) can this be pulled out and sperated and still used?
Does the ABS computer if seperate require a signal from the ECU?
Thanks for any help.
LibertySyclone is offline   Reply With Quote
Old 07-03-2008, 08:52 AM   #2
iwishiwas-all*
iwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfectioniwishiwas-all* is close to perfection
just trace the wires out, on an s13 I did that and still got it
IG @gabednconfused
https://www.youtube.com/user/gabedm
iwishiwas-all* is offline   Reply With Quote
Old 07-03-2008, 09:02 AM   #3
LibertySyclone
Yah I have no problem doing that, just wanted to make sure that they are seperate systems. (ABS/ECU) so that my ABS will work with my LS1 swap.
(I am just going to assume from your answer that this is the case)
Old 07-03-2008, 10:07 AM   #4
projectRDM
projectRDM's Avatar
Yes. There's nothing tied into the ECU for ABS control.
FORMERLY R240NA
Old 07-03-2008, 12:01 PM   #5
Ali 556
Ali 556 is a well-known jackass
my friend's LS2 Powerd S14 Still Hase ABS/Airbag/AC/PS...and now he is swaping a 550whp LS7 engine....
So yes...you can keep your ABS WITH the LSx...
Also what mount kit are you usuing....? there is a company that offer a mounts kit + Trany Mount + Oil relocat and other stuff for 1750$... WITHOUT cutting the stock cross member.... :love
Check silviav8.com for more info ..
Hope This Help,
Regards,
Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 07-03-2008, 01:11 PM   #6
LibertySyclone
I am on SliviaV8 under the same screen name.
I am using mostly the daft kit, as everything measures up to fit right so far.
The Sikky kit is the one you are talking about and yes its awesome.
My LS1(LS6 top end) should be 450+hp
Good to hear ABS is seperate.
Thanks guys!
