Old 07-03-2008, 05:35 PM   #1
Lurpin
Lurpin's Avatar
Lurpin is on a distinguished road
KA KA24DE Misfire Problem
So, for the past month or so my KA24DE has misfired a little bit, but not to often. Now today it will not stop misfiring, and now the service engine soon light is on. I changed all my spark plugs with new ones but that did not help at all. It is a 1998 KA24DE with 85,XXX miles on it. Anyone got any ideas?
Lurpin is offline   Reply With Quote
Old 07-03-2008, 05:42 PM   #2
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
sparkplug wires
importdude is offline   Reply With Quote
Old 07-03-2008, 05:47 PM   #3
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
did u gap the plugs right?
nieko is offline   Reply With Quote
Old 07-03-2008, 05:47 PM   #4
Lurpin
Lurpin's Avatar
K, I will try that out. Thanks
Edit: they came pregaped
Old 07-03-2008, 05:50 PM   #5
nieko
still, double check the gap dude ive had a few pregapped plugs that were a little off... is timing good?
Old 07-03-2008, 05:56 PM   #6
Lurpin
Lurpin's Avatar
K i will check them. I think it probably could use a new timing chain, but would that really make it misfire?
Old 07-03-2008, 06:28 PM   #7
nieko
if the chain jumpedd teeth but i highly doubt it did that. like i said check timing. get a timing gun negative to negative positive to positive on the battery, turn the gun to 0 degrees. then shine the light and look for the little pin, i believe it should be 20 degrees tdc. there is a writeup somewhere if ur not sure how. good luck
Old 07-03-2008, 08:34 PM   #8
Lurpin
Lurpin's Avatar
K Thanks man.
Old 07-03-2008, 08:41 PM   #9
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
plug wires, plug gap, distributor cap, distributor, compression, injector, intake leak. Any one of these things can cause a missfire on at least 1 cylinder.
RedtopTech is offline   Reply With Quote
