Old 12-16-2002, 09:19 AM   #1
N1ceDrgn
N1ceDrgn's Avatar
N1ceDrgn is an unknown quantity at this point
Send a message via MSN to N1ceDrgn Send a message via Yahoo to N1ceDrgn
Hello again,
It's been a little over 2 weeks now and I am getting both frustrated and worn out. When it all started, my CA idled down and died out, . After checking things my fuel pump had gotten plugged and blew the fuse, . Since, I've replaced it with the same pump, (new), and have been unable to get it started. It's been suggested that I may also have developed some corrosion and a ground some where but I haven't found it yet.
When I try to start it, it turn once or twice then idle down and die again, . I've listened to the fuel pump and it sounds like it isn't getting the right amount of power anymore. Another thing I've noticed is that when I toggle the key in the, 'ignition power on' position, my gauges will flicker and reset. COuld my ignition have gone bad as well? I'd hate to imagine that several problems developed at one time, . I REALLY need help with this. Anyone?
..working on something that is slowly getting built up and restored..
N1ceDrgn is offline   Reply With Quote
Old 12-16-2002, 11:41 AM   #2
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Start by checking all your fuses. If you can grab a psi meter from your local auto parts store and check if you have pressure in the fuel line.
Try having the car jumped as the battary may be dead.
Give us an update. If this stuff doesn't work I might have some other idea's as well.
G'luck
Driftec
www.midatlantic240sx.com
Foxcolt is offline   Reply With Quote
Old 12-16-2002, 12:13 PM   #3
SxMachine
SxMachine's Avatar
SxMachine is making a name for him/her selfSxMachine is making a name for him/her selfSxMachine is making a name for him/her self
Check injectors and fuel filter as well.
91 Bmw 318is
90 S13 (sr20det)
SxMachine is offline   Reply With Quote
