Brake fluid problem
I flushed my brakes like a month ago. A week after the flush, my brake light came on. I checked and it was low on brake fluid. I added more and no problem.
Earlier this week, the light came on again, so I checked the resovoir and it was low. I added more fluid to the max line. Two days later it is back down to almost empty. I checked for leaks and there were none. I don't know what the hell is wrong? What else should I check for? Please help. Thanks |
sounds to me like a leak
It has to be a leak... brake fluid doesn't just disappear like that! Check the hard lines under the hood starting from the MC, and follow them under your car to the calipers.
Worst case scenario, you'd have to bring it to a shop and have them help you out...
Instagram: @SX180HKG |
![]() Join Date: Sep 2002
Yeah it has to be a leak. If you are near me I could help you out...but I doubt that you are. Also...if the brake fluid is leaking onto paint....then there won't be anymore paint there. Just run your fingers down the lines and find the leak. When you changed your fluid you used DOT3 right? Cause if you used DOT5 then you have to get all new rubber seals. When you changed your fluid you bleed your brakes right? If you did make sure that all the bleeder screws are tight.(Not too tight though)
well, if you flushed em, and now it's a problem, i would guess that you didn't get the bleeder valve on the tight enough.
check your calipers around the bleeder valve to see if any fluid is leaking out. |
#5 |
AH HA! I just posted on Z32 Brake Problem about checking for leaks and stuff related to your problem. Check out that thread it should help. If not just catch me on aim and I'll try to help out some more.
#7 |
Checked it out today. Turns out to be a broken seal on the rear brake caliper. Going to get that replaced. I called a few places and they say it's like 90 bucks for one. Is that exp? How much does it normally cost?
#8 |
Well they'll probably be rebuilding the whole caliper so it sounds about right. The going rate for an hour here is about $50+parts. So it sounds about right. If you are near me I could do it but I doubt you are...
