Old 07-06-2008, 11:14 PM   #1
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
Interior wiring.. S13 hatchback!
So, I'm getting rid of everything minus the rear taillights with the harness that goes to the rear and I just undid an entire harness that goes around to the back..
i cut out the wiring harness for under the center console too..
now.. i fear i may have just opened up a can of worms that i'll never untangle?
anyone done re-wiring the interior for just the bare essentials?
lmk any tips!
My iTrader rating!
babowc is offline   Reply With Quote
Old 07-06-2008, 11:53 PM   #2
mrmephistopheles
mrmephistopheles's Avatar
... so you basically cut a whole bunch of wires without considering what they were for?
I recommend you completely strip your interior and track back all the wires you cut to see what they were for.
Anything you don't want to run, cut it out, but take your time and don't fuck up. Electrical fires aren't as fun as everyone says.
Fun Fact - I'll be rewiring *my* car to ADD shit that wasn't there previously.
Originally Posted by PHLIP
Old 07-07-2008, 06:51 AM   #3
g6civcx
g6civcx's Avatar
If you don't know what you're doing, then why are you doing this? The weght saving is minimal.
lmk any tips!
Yes, I have completely rewired my car from scratch, but I have experience so this stuff is no big deal.
It's not hard but it's not simple either. My advice is to leave the wiring stock. If you want to save weight, clean out your car, especially the area between the fenders and the body where rocks and debris tend to collect.
Do you have any specific question?
Old 07-07-2008, 08:18 AM   #4
babowc
babowc's Avatar
Hm.. I was trying this to run a couple wires to the brake lights and make things a little less confusing but i made things more confusing
also removing the fuse boxes from the engine bay under the dash..
maybe im in over my head.... lol
i'll see what i can do tomorrow
My iTrader rating!
Old 07-07-2008, 09:34 AM   #5
krazydriver
krazydriver is making a name for him/her selfkrazydriver is making a name for him/her self
I did something similar removing the "non-essentials".
Easiest way to keep it neat is to start at the connectors going to what you don't want. (ie, remove the read speaker, take the plug and as you unwrap the harness pull that connector/wiring out)
This way your not cutting in the middle then trying to find where it goes.
Work from the ends, back to the huge junction in the dash, then just pull the pins out.
I will admit though, it was crazy and took quite awhile to get everything finished up. I did what i wanted, but honestly, you are better off just leaving it.
krazydriver is offline   Reply With Quote
Old 07-07-2008, 09:47 AM   #6
mrmephistopheles
I need to redo all the wiring on my car. My audio system wiring is an abomination. Also, the super margarita machine won't wire itself.
Old 07-07-2008, 10:10 AM   #7
sliksta1
sliksta1's Avatar
sliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura aboutsliksta1 has a spectacular aura about
oh your gonna have a headache connecting the right wires back together. i would have started with the connectors to the tail lights, peel back the wires that werent being used and work my way to the front removing any other wires that are not being used. this way you know what wires to leave and what they belong to. good luck. shits gonna be time consuming
sliksta1 is offline   Reply With Quote
Old 07-07-2008, 11:01 AM   #8
awesomenick
awesomenick's Avatar
Trader Rating: (33)
awesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfection
Feedback Score: 33 reviews
When rewiring your chassis, don't forget the fuel pump also needs some wire. haha. Not just the tail lights.
awesomenick is offline   Reply With Quote
Old 07-07-2008, 11:08 AM   #9
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
I rewired my coupe and it was pretty easy. Like Mr Meph said just follow the wires to see what they are for.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 07-07-2008, 11:12 AM   #10
babowc
babowc's Avatar
I think the fuel pump uses a different loom of wire, so i should be good.
i did go from the connector down to the big 'socket'..
i did get rid of the entire center console harness and that proved to be more of a bitch than the rear wires.
Also.. some wires loops back into each other, usually ground wires (blk) were like that.
I can just re-connect the two together and complete the circuit, correct?
I also got rid of everything hvac related, so i wanted to just eliminate all the wiring for it.
it's a big pain in the ass, though. haha.
ill get on her tomorrow all day.
My iTrader rating!
