Old 07-12-2008, 09:47 PM   #1
Jonnyblaze
Jonnyblaze's Avatar
Jonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymore
which 5 speed swap guide to follow?
hey guys, planning on doing a 5 speed swap soon and was just wondering which guide was the most thorough and accurate.. i have an s13 so please take this into consideration. ive searched around but considering i havent done the swap i dont know which guides are the best. thanks for the help
'91 Hatch - Work in Progress
Jonnyblaze is offline   Reply With Quote
Old 07-12-2008, 09:56 PM   #2
corriganjoshua
corriganjoshua's Avatar
corriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfection
Send a message via MSN to corriganjoshua
There is really nothing to it as long as you have all the required parts its all common sense no accuracy needed. www.heavythrottle.com is descent though
Team Inertia
Cheap,Fast,Reliable you can only have 2.
corriganjoshua is offline   Reply With Quote
Old 07-13-2008, 09:45 AM   #3
thejapino
thejapino's Avatar
thejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfectionthejapino is close to perfection
Add all of the guides to your favorites and read them all. Take a little from each of them b/c it seems like some have alot of info on the r&r, some have alot of info on whats needed to make it work, some deal with the lower harness, etc, etc.
WTB: 13kg springs! Eibach, Stance, or Swift.
thejapino is offline   Reply With Quote
Old 07-13-2008, 10:21 AM   #4
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
I see alot of scattered writeups. I wonder if we should compile everything and rewrite it. Im getting ready to do a swap and could use a for certain guide
Bigsyke is offline   Reply With Quote
Old 07-13-2008, 12:07 PM   #5
projectRDM
projectRDM's Avatar
If you're able to attempt it and feel confident doing it, you don't need a writeup, guide, or any instructions. It's really that simple. Remove the auto parts, install the manual parts. It's nothing but common sense if you have the mechanical skill to do it.
FORMERLY R240NA
Old 07-13-2008, 09:01 PM   #6
Jonnyblaze
Jonnyblaze's Avatar
are all the 5 speed parts from a sohc s13 compatible with a dohc s13? of course the ecu is different but is everything else the same?
Old 07-13-2008, 09:35 PM   #7
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
I thought you said you read up on this? Yes, the parts are interchangeable. Just be sure to buy a clutch kit or if just the throwout bearing for an SOHC, not a DOHC. It's really a straight forward swap.
If you want you can PM me and I'll answer some questions you may have on it.
- Jimmy
Wanted:
TBD
For Sale:
TBD
