Old 07-17-2008, 10:07 AM   #1
jaytv1019
jaytv1019 is an unknown quantity at this point
Red Zenki/built SR/Car PC - needs to go!
Hey guys, the time has come to move on to the next project. I was going to wait until the end of the season to sell her but I came across a real nice deal on something and can't pass it up. The only problem is that I cannot afford them both - so unfortunatel my girl Sil has to go.
There is well over $30K in parts/labor/etc and I have listed her for sale before (low $20Ks) but was never serious about selling her. Well now I am, so I am listing her for $15K which I am very firm on. Not saying I wouldn't take offers but for everything this car has, I (of course I do) think it's a steal.
Location - Chicagoland area
Price - $15,000
History, I did build this my self from the ground up. The engine currently has ~4500 miles since rebuild and it runs like a champ. I did have a problem with what I thought was the headgasket a couple months back but I re-torqued the headstuds and the problem hasn't been back since. I am not going to say I babied the car but I most definitely didn't beat on it. She was drivin hard and only launched once. She has scene no drag strips and only one auto-x. The car is tuned perfectly with a rom tune (11.5s across the board) and doesn't stall, miss, hiickup , or anything. The throwout bearing has a little whine to it but the trans shifts perfect with no grinding. The windsheild is cracked but not bad (will replace with sale) and the paint is a 8/10. The hood is not painted and the dash has one crack in it on the steering column.
I am a real honest guy and will tell you anything you want to know, good or bad. I hate to see her go but gotta make room for her bigger brother
Brake/suspension/wheels -
Z32 front calipers
5-lug conversion
ES master bushing kit
KYB adjustable shocks
Eibach prokit springs
SS brake lines
Sportmax 5 spoke 17 x 7.5 front 17 x 8.5 with 3" lip rear
Kumo 235/45/17
1.5" spacer in front
1" spacer in rear
New ball joints
Interior/electronics-
Brand new carpet, grey
New interior pieces
8.5" monitor molded into dash for CarPC
MCS 1.8 gig processor with 120GB hard drive
Nissan datascan consult program (used as engine diagnosis and gauges)
Innovative WBO2 sensor, gauge viewed on computer
Autometer silver boost gauge and oil pressure gauge
Custom fiberglass gauge pod in door for boost gauge
1 10" RF sub in custom fiberglass enclosure
Focal 6.5" component speakers in front
Alpine 5 channel amplifier
Touch pad for computer controll in steering wheel (this is awsome!)
Rotory system volume controll
Battery mounted in trunk with 0 gauge wiring and circuit breakers
SAFC NEO for fine tuning
Enthalpy rom tune (OEM ECU)
Body/chasis-
Fresh Nissan red paint
Knock off/remade fiberglass body kit
Silvia bages
Silvia grill
Unpainted fiberglass hood
Silvia fiberglass replica OEM wing
Silvia rain gaurds
Engine -
Full Race Twin Scroll kit w/GT3071r v-band
Apexi N1 Exhaust, resonated test pipe (super quite @ idle)
Z32 MAF
Q45 igintor
eBay lightend pulley kit
740 cc injectors on top feed fuel rail
Aeromotive FPR
Greddy FMIC
Greddy RAS
Greddy Intake manifold
Tial 50mm bov
Tial 44mm v-band wastegate
Custom catch can/coolant overflow setup
Koyo radiator
B&M short shifter
Spec Stage III clutch (good to over 500 whp)
J30 (infinity LSD)
Brain Crower valve springs
OEM retainers
Brain Crower 264* Stage I camshafts
Mahle treated .20 over 86.5mm 8.5:1 CR pistons
OEM connecting rods
Tomei 1.5mm metal head gasket
ARP head studs
ARP rod bolts
ARP main studs
OEM water pump
OEM oil pump/front cover
OEM clutch slave
OEM EVERY GASKET & SEAL NEW
ARC over sized oil pan
Heat wrap on downpipe, turbo lines, intake pipe
All vaccum lines are stainless steel braided with red/black hose ends
All fluid lines are stainless steel braided with silver/black hose ends
All intercooler piping powdercoated "smoked chrome"
Intake manifold powdercoated "flat black"
Two tone valve cover "mirror red" and lettering "flat black" with clear coat
Engine bay painted textured flat black high temp
jaytv1019 is offline   Reply With Quote
Old 07-22-2008, 07:19 AM   #2
jaytv1019
any questions or offers?
Old 07-22-2008, 08:54 AM   #3
hey808
hey808 is a well-known jackass
I'll vouch for the seller. He took his time with the build, didn't cut corners, and used quality parts.
Bob
'92 Coupe
hey808 is offline   Reply With Quote
Old 07-22-2008, 01:20 PM   #4
0100
0100's Avatar
0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute0100 has a reputation beyond repute
Very cool carPC.
TougeHero.com l SilviaV8forums.com
0100 is offline   Reply With Quote
Old 07-23-2008, 09:38 AM   #5
jaytv1019
Thank you, it controlls everything. It stores around 3,000 songs, it runs nissan datascan to monitor the ecu/engine. I can set timing, idle, and check codes from the computer it self. Very cool little tool.
Old 07-28-2008, 08:31 AM   #6
jaytv1019
price reduced to $14,995 -
Old 07-28-2008, 12:34 PM   #7
Dominic Axelson
Dominic Axelson's Avatar
Dominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfectionDominic Axelson is close to perfection
Send a message via AIM to Dominic Axelson
i would nag you about the price, but it would only be because im mad i dont have the cash for it... glws
Dominic Axelson is offline   Reply With Quote
Old 07-28-2008, 04:52 PM   #8
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
how much did it run you to do the carpc ? and what did you use ? and who made that screen ? I was thinking about running a mac. any ideas ?
TougeLabs is offline   Reply With Quote
Old 07-30-2008, 09:45 AM   #9
jaytv1019
lol - that's cool. I get sh@# on all the other forums for the price.
The car pc was around $1,200 not installed. I did the whole install myself so that was pretty cheap but at my shop we would charge around $400 to mold the screen in the dash.
I love the whole carpc thing and I do believe that with in the next 5-7 years, that will be the standard in all cars in some way (pioneer already makes a multimedia storage thing). Don't know much about macs but why not try it. I bought my pc from mobile computing solutions and it is made for a car. Comes with some nice features like auto shutdown.
Old 07-30-2008, 12:54 PM   #10
runnin13s
runnin13s is an unknown quantity at this point
trade for a 2005 turbo GSXR 750?
runnin13s is offline   Reply With Quote
Old 07-30-2008, 02:33 PM   #11
CylonFrakker
CylonFrakker's Avatar
CylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond reputeCylonFrakker has a reputation beyond repute
Send a message via AIM to CylonFrakker
wow great looking car love the looks and style!
UGR.....SOMETHING WICKED THIS WAY COMES....
CylonFrakker is offline   Reply With Quote
Old 07-31-2008, 10:12 AM   #12
jaytv1019
Thank you,
sorry, can't trade - need some cash for a new project.
Old 07-31-2008, 10:26 AM   #13
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
very nice dude good luck with sale.
Smurf_240SX is offline   Reply With Quote
Old 08-31-2008, 07:10 PM   #14
jaytv1019
Thanks- how about $14K?
Old 09-01-2008, 01:00 PM   #15
dookiedang
dookiedang is on a distinguished road
Send a message via AIM to dookiedang
hmmm silvia's big older brother!?!?!? you doing a project Z???
dookiedang is offline   Reply With Quote
Old 09-03-2008, 07:12 PM   #16
jaytv1019
nope.. It was a R33 GTR with a popped motor but that deal came and went. Now, I just want to sell it for a family ride. Wife had to get a full time job and we only have one "baby" car. Time for another!
Old 09-14-2008, 09:05 AM   #17
nnorris7413
nnorris7413 is an unknown quantity at this point
Would this classify as a family car?
FEELER FS: 2002 M3 6sp JB/Cinnamon (IL) - BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3)
Also, is there no A/C on the car?
nnorris7413 is offline   Reply With Quote
Old 09-14-2008, 03:48 PM   #18
UfoZ8myCow
UfoZ8myCow's Avatar
Does the carPC control like AC and stuff? Or is it removed?
UfoZ8myCow is offline   Reply With Quote
Old 09-14-2008, 06:52 PM   #19
Johnnyall
Johnnyall is an unknown quantity at this point
trade for an r32 gts-t?
Johnnyall is offline   Reply With Quote
Old 09-25-2008, 07:32 PM   #20
jaytv1019
Hell yeah I would trade you for that M3 - I actually was talking to someone about selling the car and I was going through the receipts and I totalled ~$35K. I am going to either just keep it or raise the price. I am not going to give this car away, especially since I have been driving it more and more as of lately. I was trying to get rid of it fast but I just came into some cash and no longer "need" to sell it.
There is no AC but the heater and vent controlls are relocated to the center box. I would love a R32 but you know I am in the states (can't have one legaly) and I am a little jealous that you guys up in canada are able to have those.
