Old 07-21-2008, 05:42 PM   #1
1slowS13
1slowS13's Avatar
1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice
Magnetic Drain Plugs
This is a copy-paste article from jdm-insider.com
I thought it was a very interesting read. While searching for key words, I found some threads with people asking about them, so..
"Somebody forwarded this email to me today where this new company, Titek, was promoting their magnetic drain plugs for an engine’s oil pan. While the concept is somewhat novel, it’s application is kind of dumb. A magnetic drain plug (mdp) has its place in a transmission with steel gears or a rear end with steel gears and metallic clutches where bits of steel can actually float around in the oil. However, a mdp actually has no place in an engine’s crankcase if you really think about it. In the remote possibility that your engine’s cams are gear driven, an mdp might have a place, but chances are if you are reading this blog your engine does not have gear driven cams.
Let’s think about what’s inside of an engine block for a second here: a crankshaft, bearings, rods, pistons, wrist pins, pin clips, and piston rings. The crank, rods, and pins are all riding on films of oil. The pin clips hold the wrist pins in place and the piston rings are held in place by the piston’s ring lands and neither bits of clips or rings can come out unless a catastrophic failure occurs. In the head, you have cams, followers, springs,retainers, and locks. If any of these components fail, the last thing you need to be worrying about is catching bits of steel at the very bottom of an oil pan with a mdp.
So in a healthy engine, what’s the purpose of having a mdp? The only components that can wear are the bearings and at that point your engine has become unhealthy probably due to a cracked oil pump rotor, oil pickup tube, lack of oil or pump cavitation and is living on borrowed time anyway. Bearings consist of lead, tin, copper, and sometimes babbit and/or aluminum. The last time I checked, none of these elements were magnetic because they are non ferrous. If the steel components break (crank, rods, pins, clips, or rings) or chip, the last thing you need to be worry about again is catching bits of steel at the very bottom of the oil pan with a mdp. You will more likely be either on the side of the road or track with a hole in your engine block and waiting for a tow truck. No mdp no matter how strong it’s magnet is, is going to save the day.
While technically it cannot hurt to use an mdp on your engine’s oil pan, it has no merit either. I’m not bagging on Titek since I know nothing about their products and I’m sure there are other companies that make mdps. I’m just making a point that mdps are useless. Some companies like to make products to increase sales so you can spend your hard earned money. That’s ok, but spend it on something that’s worth a shit."
http://jdm-insider.com/Blogs/Eric/?p=889
1slowS13 is offline   Reply With Quote
Old 07-21-2008, 05:46 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Hmm I don't know about you guys, but when I do an oil change theres usually a small cluster of metallic particles attached to my drain plug, so I consider it to be helpful.
Old 07-21-2008, 05:49 PM   #3
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
Yup, first oil change w/ it was pretty nasty. I'd rather have it on the plug than floating around.
Subsequent oil changes almost nothing, but still tiny specs here & there.
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 07-21-2008, 06:20 PM   #4
2Slow40
2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute2Slow40 has a reputation beyond repute
Did you just straight copy this thread from NicoClub? lol
2Slow40 is offline   Reply With Quote
Old 07-21-2008, 06:35 PM   #5
1slowS13
1slowS13's Avatar
Yes. I, too am on there.
Old 07-21-2008, 06:37 PM   #6
2Slow40
Haha I'm just messing with you man.
Old 07-21-2008, 07:06 PM   #7
S14DB
AFC #1
S14DB's Avatar
Honda blog?
Steel is the only ferrous metal? Damn, if those Iron sleeves in your block wear...
Old 07-21-2008, 07:25 PM   #8
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
I've noticed the magnetic drain plugs are more effective on your tranny.
Plus do NOT order the PWJDM ones. I bought 2 sets for my civics, and one set when I pulled apart the magnets, one of the magnets came out of the socket. (the 2 drain bolts attach themselves together in the packaging) Held on by a very thin elmers green colored goo.
I then pulled all of the magnets apart and JB welded them back in, let them dry for 2 days, sanded the jb weld down, applied another coat. Did that 3 times. Dont want a magnet walking up the crank
Bigsyke is offline   Reply With Quote
Old 07-21-2008, 07:31 PM   #9
alexander500
alexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond repute
So according to this email I am wasting my time with the oil filter too.[Sarcasm]
alexander500 is offline   Reply With Quote
Old 07-21-2008, 07:38 PM   #10
Bigsyke
Bigsyke's Avatar
oil filter in general? or filter magnet? because those have been noted to do more harm.
Old 07-21-2008, 08:46 PM   #11
warpd
warpd is making a name for him/her selfwarpd is making a name for him/her selfwarpd is making a name for him/her self
Ditto, every time I change my oil there are metal particles on the drain plug.
warpd is offline   Reply With Quote
Old 07-21-2008, 09:39 PM   #12
Avante
Avante's Avatar
Avante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfectionAvante is close to perfection
filter magnets do harm?
please elaborate.
i have a power enterprise filter, and it comes with a magnet.
should i be worried?
Avante is offline   Reply With Quote
Old 07-21-2008, 11:06 PM   #13
blownmotor
blownmotor's Avatar
blownmotor is on the path to ruinblownmotor is on the path to ruin
Your oil does pick up metal from wear on you engine. I've had a Project Kics Mag drain plug for two years now and every time I open it it has a very small residue on it(it's not oil either). So whatever magnetic particles it picks up it stays there instead of circulating around in your engine/turbo. Better safe than sorry IMO.
blownmotor is offline   Reply With Quote
Old 07-22-2008, 02:08 AM   #14
!Zar!
!Zar!'s Avatar
Damn negus. All this talk about an magnetic oil bolt?
I only care about one thing and that's that my oil isn't dark as a fuckin negus.
Old 07-22-2008, 08:21 AM   #15
alexander500
The theory in this email suggests that there is so little or no friction or wear in a "heathy" engine that there is no need for any sort of cleaning/trapping device.
I have one of these mdp's and when I change my oil there are metal particles stuck to it. Particles that would other wise be working their way around engine and possibly causing damage.
The point I am tring to make is; this email and it's content is misleading. The author sounds intellegent, but in fact his reasoning is weak:
-Transmissions need magnetic drain plugs because they have gears and gears on gears wear making metal debis.
-Engines don't have gears, so there is no wear, so no need for a magnetic drain plug
I am not saying that if you don't have one you are going to die, rather that they are not as usless as the OP seems to suggest
Old 07-22-2008, 10:38 AM   #16
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Plus it doesnt hurt to pay only $10 for a plug..its not like fuck i just spent a couple hundred and it doesnt even work..plus when I do an oil change..yup..metal particles are there a little bit..
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 07-22-2008, 01:32 PM   #17
g6civcx
g6civcx's Avatar
My brand new GM crate engine is as "healthy" as a motor can be. Every time I take off the magnetic drain plug, I see a lot of metal particles accumulate on the magnet.
Every one of my car has a magnetic drain plug, and every time I pull the plug I see some kind of debris.
If they all come out clean then I would consider not buying magnetic plugs again, but based on my personal experience I will continue to use them.
Old 07-22-2008, 01:44 PM   #18
Bigsyke
Bigsyke's Avatar
MDP are good if they are durable. FilterMAG's are bad. Some have been noted to affect the bypass depending on the filter used. Do NOT use a FilterMAG.
Old 07-22-2008, 01:50 PM   #19
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
dude the magnetic drain plug in my diff saved me when my welded diff exploded because the big pieces were caught so the magnetic drain plug can save you in a worst case scenario.
wow-thats-a-cool-car is offline   Reply With Quote
Old 07-22-2008, 01:56 PM   #20
g6civcx
g6civcx's Avatar
Read this again.
Originally Posted by 1slowS13 View Post
A magnetic drain plug (mdp) has its place in... a rear end with steel gears and metallic clutches
Your comment is not germane to the discussion because we're discussing engine oil pan drain plugs, not diffs.
Old 07-22-2008, 02:06 PM   #21
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
Honestly there's lots of impurities floating around. From your engine to your engine oil. Yes your engine oil does contain some. It's not a perfect world but we can try to minimize the ill effects with some band aid fixes here and there. I would also like to know how filter magnets are creating problems?
Bigsyke, please provide some evidence of all these harmful claims/situations.
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 07-22-2008, 02:17 PM   #22
Bigsyke
Bigsyke's Avatar
Cut open a filter and place filter mag near spring. Its enough to affect the bypass on smaller filters. Ive talked to some engineers about the filtermags being so strong they can possible magnetize particles, and having them cling on places you dont want.
A good quality MDP does the same thing everytime you turn the car off, and is $30 cheaper, and would no way affect bypass pressure. It catches the particles before they hit the pickup/filter further lengthening the life of a filter on initial start up.
Old 07-22-2008, 02:24 PM   #23
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Every time I've ever pulled out a mdp, it has metal particles on it. It just grabs some of the bigger crap before the filter can get it. Who cares, they're super cheap and add marginal additional pre-filtering abilities...
MELLO*SOS is offline   Reply With Quote
Old 07-22-2008, 02:29 PM   #24
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
i just like em because i dont have to fish for the plug in my drain pan...all i need is a wrench and no oil burn for me LOL
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 07-22-2008, 02:36 PM   #25
g6civcx
g6civcx's Avatar
Protip: when removing the drain plug with your fingers, push up so that the plug seals oil in the pan. When the plug is completely loose, take the plug away in one swift motion.
If you do it right, you should have no oil on your hand. It may also help if you hit the plug with some compressed air or brake cleaner before you touch it so you don't burn yourself.
Some people can do it just the socket and never having to touch the plug with their fingers, but that's too much manual dexterity for me
Old 07-22-2008, 02:53 PM   #26
Bigsyke
Bigsyke's Avatar
why not get a pair of latex gloves on, and wait for things to cool down? I love the concept of a hot oil change, but what justifys building oil pressure quicker vs having a proper lb/ft reading and a good seal?
I think the moral is MDP's are great, dont do ANY harm ~ as long as it wont fall out of the drain plug.
Old 07-22-2008, 03:05 PM   #27
g6civcx
g6civcx's Avatar
I agree. Oil causes cancer.
I prefer the cold oil method for safety reasons as well.
Old 07-22-2008, 04:21 PM   #28
drift into a curb
A "good" quality MDP still doesn't have much effect because it has to come in direct contact with the metallic particle. The MDP doesn't go searching out metallic particles in your oil... only the ones it comes in contact and it's highly unlike it'll see every bit of oil. And you don't do it to lengthen the life of the filter, but rather keep micro particle contaminants from causing wear and tear on your motor.
The filtermag would have to be pretty close. Less than an 1/8" away from the bypass spring... It's possible to worry if it was such a small filter, that the magnet surface area somehow the filter just took up the whole area.. or if the magnet moved around, but that actually doesn't happen. Once it's stuck on there, it shouldn't be attached anywhere near the bypass spring and it's stays put, but yeah, your claim is substantiated by anything other than assumptions. Just FYI, I have rebuilt a SR with a filter mag and haven't had issues as of yet and prior to this I had a rebuilt KA motor. I wouldn't go as far as badmouthing it without any actual experience.
Go big or go home!
Old 07-22-2008, 04:25 PM   #29
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
i know all that...but theres those times ur hands slip up an dit still falls inside, ask anyone...im lazy
PSN
Old 07-22-2008, 05:26 PM   #30
Bigsyke
Bigsyke's Avatar
Im saying I wouldnt myself get one for my own reasons. I change my filters enough to not have to worry about metal shavings in the filter. The price offset isnt worth any potential trouble it COULD make.
Myself am a believer that any metal shavings flowing across such a highly magnatized area could magnatize the particles themselves. I have an mfactory magnetic drain bolt. That thing could fish out particles in your oil like you couldnt imagine.
I tried putting some metal shavings in a bucket, the MDP does a fine job, and id rather opt for an amsoil Eao filter
