![]() Join Date: Jun 2008
Trying to track down a rattle. I have searched, but have a couple questions.
Hi,
I've been searching though this forum for the last couple hours reading through all the threads on rattling on the KA24DE. I've come across a couple possibilities, but wanted to ask a couple specific questions to my issue. I have read that the possibilities to the 'rattle' could be the following: 1. Timing chain guides. I have removed the top, but not the lower. I know I saw a walkthrough on this somewhere but I can't find the damn thing now. I might have missed it when sifting through search results. If anyone has the link offhand, +rep for joo. I'm not 100% sure this is my issue though. I will explain below. 2. Loose valve cover. The is one bolt, that was stripped or the threads were gone on the cover. I'll have to run out to my car on my break and verify which it is. I had to use what I could find, and while i believe the cover is correctly seated and sealed (yes i replaced the gasket), I still don't believe this is my issue. 3. Motor mounts have gone to crud. This could be a possibility, but I'm not sure based on the info below. Now let me explain my rattle. The rattle itself literally sounds like it is right under the valve cover, although I haven't tested this with 2 people. It sounds like metal bouncing around a hollow area, like the timing belt hitting the valve cover for a few seconds, but i'm not 100% sure on this, and I doubt thats what it is. Just trying to give the best description of the sound. -This only occurs after my car has been sitting for a while, like overnight or the whole day while I'm at work. It will happen everytime in this circumstance. -This only occurs right when I start the car, and for a few seconds after. -If I drive the car for a bit after it happens, then restart it after parking for a few hours, it does not occur. -The rattle does not occur at all once the car has been started and the initial rattle has disappeared, only after it sits for an extended time. -This has been occuring as long as I remember with this motor. I swear it feels like the oil is draining from the upper areas of the engine and they are recoating when this occurs. The reason I don't think its the timing chain guides or the valve cover is because this only occurs at startup, not at any other time. I have used nothing but Mobil1 10-30 since I got this motor (had the car since 99[yep, back when it wasn't trendy to own an s13], 3rd motor, yes, i was young and dumb and drove the shit out of the first two, but have taken the best care possible with the newest one). There is roughly 70k-90k on the motor and it appears to run great, acceleration is clean, except for a slight delay once in a while in third gear right after shifting when the car hasn't fully warmed up. I have had 2 mechanics look into this issue and neither have been able to give me anything (probably because the frequency that it occurs). I am the third owner and the car has a clean title, according to Carfax. If there is any information you need, just ask. Please be kind though, I'm still learning how to work on my motor, and am somewhat nub to the slang. I can preform most maintenance, but have never rebuilt a motor. I am loving this site and read it as much as possible to soak up info. And yes, I bought a premie membership right away because after all the info I've taken off this site, I felt like I should give something back. I feel like I'm at the point where I need to find an s13 expert mechanic to get this resolved. I trust my mechanics, but they are shops that work on all kinds of cars. Any help or guidance on this is greatly appreciated. Also, sorry for the long post, I wanted to explain this as best I could. |
