Old 07-25-2008, 01:47 AM   #1
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
ka rebuild coming together!
well, i replaced the piston rings, main bearings, rod bearings, block machined and re-honed, prepped the oil galleys, polished crank, full gasket set, oil pump, timing chain kit, water pump, thermostat
and took the head to the shop to get re-ground, turns out there was a lot of problems with it, so that cost about $300! well worth it though
i have a question about the vaccum lines, anyone familiar with removing the mess of hardlines behind the head? will my the engine run the same without it? also known as "butterfly removal"
Options13 is offline   Reply With Quote
