Old 12-27-2002, 11:22 PM   #1
MyFirst240SX
MyFirst240SX is an unknown quantity at this point
Oh no, no bolts on my exhaust manifold
I have had a wierd ticking noise in my engine bay i traced to my exhaust manifold and today i took the sheild off of the manifold and only one side of the manifold has bolts! the to wouldn't take a new bolt and the stud that should be at the bottom isn't there.
does this mean i have to tap/die my engine :/? is this happen much?
sean
It is better to drive a Slow car fast than to drive a fast Car slow!
'89 FastBack 5spd: Intake/Exhaust,Strut Bars and JL15.
'90 Parts car/Some day drag car.
MyFirst240SX is offline   Reply With Quote
Old 12-28-2002, 12:07 AM   #2
West
OMNOMNOMNOM
West's Avatar
West has disabled reputation
Send a message via AIM to West
No you can fix it real ezily with the bolts from Nissan that you can get for about $4 a piece. Use lots of wd-40 and get new gaskets and it should be fixed in about 30 min. I didnt have to tap/die my bolts because they were just missing off my 89 SOHC Jalopy, although one of the bolts I couldnt get it, it didnt leak anymore because of the new gasket. If they are broken then get a drill set with a screw extractor, Sears sells them.
West - Zilvia.net - Toyobaru.net - NapkinSketch.com
West is offline   Reply With Quote
Old 12-28-2002, 12:56 AM   #3
MyFirst240SX
thanks mark
Old 12-31-2002, 05:43 AM   #4
onboost
onboost is an unknown quantity at this point
might want to put a new exhaust gasket too.
the existing gasket might have being blown since it did not have strong even clamping force across the flange. Also the flange might be warped a bit from the hot exhaust gas escaping to only one side.
New gasket is probably recommanded
onboost is offline   Reply With Quote
Old 12-31-2002, 01:31 PM   #5
MyFirst240SX
i just bought two gaskets, 2 studs, two bolts, two washers so i should have fun tomorow
sean
Old 12-31-2002, 07:20 PM   #6
onboost
good luck!
