Old 08-02-2008, 06:43 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
s14 which fuel line is feed and return on chassis?
so basically the fuel lines off my chassis are a little tweaked, and i cant tell which is feed and which is return. in relation to the frame rail, which is which?
if it matters this is on a 98 s14.
thanks.
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 08-02-2008, 07:04 PM   #2
g6civcx
g6civcx's Avatar
Yes, it does matter.
Feed line comes off the pump and return line doesn't.
Old 08-02-2008, 07:15 PM   #3
burnsauto
burnsauto's Avatar
17506Q- return line.
one in the middle should be the return
and one on the left (while sitting under the car, feet at the diff) is the evap vent line
line coming off the fpr is the return. one coming off the filter onto the rail is the sending.
Old 08-02-2008, 07:19 PM   #4
g6civcx
g6civcx's Avatar
That diagram only works if your lines are intact. It's best to go straight from the tank and follow the line to the front.
Old 08-02-2008, 07:29 PM   #5
burnsauto
burnsauto's Avatar
ah, read the original post too fast....more info added. weather or not it will help...we'll see.
Old 08-02-2008, 08:10 PM   #6
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Feed is the one with the fuel filter. Not sure if you still got it or not.
CLICK HERE!!!
Old 08-02-2008, 08:24 PM   #7
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
was going to say the same, but to me that much is common sense.
onehundredoctane is offline   Reply With Quote
Old 08-02-2008, 08:58 PM   #8
cotbu
cotbu's Avatar
If, I could not figure out which line was what? I would extend both lines, place each line in a bottle and give power to the pump.
or do this
it's best to go straight from the tank and follow the line to the front.
What if I get the lines mixed up half way? Use tape every foot like breadcrumbs Hansel. J\k
Old 08-02-2008, 09:51 PM   #9
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
its more an understanding of the system than common sense. most dont couldnt even identify the filter let alone know if it should be before or after the injectors
surreybc is offline   Reply With Quote
