Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Nissan News
Nissan News Nissan related news about the 240sx, Silvia, Z cars, or anything that may be of interest to Zilvia.net
Old 08-03-2008, 12:40 PM   #1
ZilviaBot
Zilvia.net Bot
ZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to allZilviaBot is a name known to all
Post Dynolicious vs. V-Box and Dynojet
08-01-2008 01:58 PM
Filed under: ,
Click any image for a larger version.
Give us an iPhone application that relates to cars and we're all over it. Apparently, so is the crew at Motive. They took out an Audi S5, mounted a Racelogic V-Box onto the windshield and brought along a Dynolicious-equipped iPhone to see how it stacked up.
The V-Box uses both GPS and yaw sensor data to serve up 0-60 times, 1/4-mile trap speeds and lateral Gs, whereas the iPhone only makes use of yaw information to deliver the same numbers... along with estimated horsepower figures. While Motive wanted to find out how the Dynolicious would do with 0-60 times, we were interested in how close it would come to wheel horsepower given both an estimated weight and drivetrain loss. That meant hitting up the Dynojet at Modacar and strapping our own Project Track Slut onto the rollers.
Read on for both Motive's conclusions and our own.
Continue reading Dynolicious vs. V-Box and Dynojet
Â*
Permalink | Email this | Comments
More...
ZilviaBot is offline   Reply With Quote
Old 08-03-2008, 10:30 PM   #2
slider2828
slider2828's Avatar
That is awesome... WHen tuning anyways, AFR and percentage of change in HP is probably good enough so as not to worry.... But still for 13 bux...that is pretty accurate.... A real accelerometer is pretty expensive as they failed to mention....
Turn and Burn!
Old 08-04-2008, 06:37 PM   #3
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
works pretty shitty on EDGE iphone's
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 08-05-2008, 03:13 PM   #4
Def
How so? Does it use GPS data as well on the 3G iPhone?
HTML code is On
