Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
KA-T stumbles and has no power
I tried KA-T.org already and got almost no responses, so I figured I'd ask here.
I went to the track shortly after getting my new car put together. On the way there we discovered my BOV was too tight, and that's why I stumbled at full throttle, after I adjusted the spring on my BOV, the car ran great, boost and power all the way. After a while I was a little curious and did a BOV delete set up (compressor surge) Needless to say it didn't work well, so I put the BOV back in, and now the car stumbles at more than half throttle. The turbo will spool (you can hear it) but it runs rich, and doesn't pull the car at all. I'm not sure what it could be, my friend went off track a lot, but I don't think that has anything to really do with it. I need to do a tune up, (plugs and wires) but the car ran fine for the entire track day. Why would the set up change now? I have no meters to gauge my boost, temp, or oil pressure, I'm pretty much going from the butt dyno here. BTW KA24DE T28 450cc deathwork (haha) injectors Z32 MAF ARC BOV Enthalpy ECU tuned for my specific set up.
![]() Best way to do business with me? Make your best offer FIRST. |
Are you sure there's not a leak at the BOV?
My seller review thread |
Super Moderator
Trader Rating: (73)
I can try tightening it, but it was too tight before, I'll try that when I get off work.
So it was running fine with the properly adjusted BOV.
You removed it and then you put it back in. Now no power and running rich? My guess is air/boost/leak problem. I would get a boost gauge to see if you're even boosting or if there is a boost leak somewhere. But man...going to the track on a custom KA-T setup with not even a boost gauge...kinda like driving at night without headlights |
#5 |
![]() Join Date: May 2004
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
Sounds exactly like a car w/ a boost leak, especially since you are running MAF...
if it's not @ the BOV, it could be anywhere on your intercooler piping. Either when you did the "bov delete" or from the off track excursions, you could have created a leak in any one of the couplers on the piping.
bew bews! |
#6 | |
Maybe there's a leak where you mounted it? I'd just check everything over really well and make sure you didn't miss anything.
#10 |
No Limit Soldier.
![]() Join Date: Jan 2006
Agreed.
Leaking boost homie. KA-T's always pwn YOU! ![]()
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only" |
#14 |
![]() Join Date: Nov 2004
Hahaha.
Could've done it today. Could be doing it right now. I'm wired off energy drinks and coffee. Shit. Uhh... Wake me up and I'll deal with it before I head out. hahaha. Hyper as fuck... shit.
#15 |
![]() Join Date: Apr 2008
check the manifold where it meets the turbo, i know i had similar issues and when i pulled my mani and turbo 2 of the nuts had backed out and the other 2 were very loose. not to mention the gasket had blown out
