![]() Join Date: Jun 2008
i have an ignition problem
1990 240sx
sr20det swap I have wired the entire the car. All the electrial works. Battery has a good charge, but when i turn the key in the ignition nothing happens. Althought i do hear a clicking sound everytime coming from the relay box on the drivers side. Also checked the starter, and it works. There is one thing i think i might be but im not sure. When the Ka24 was taken out the car some of the wires going to the altinator and starter were ripped so i had to connect the wires that went to the starter and altinator(orginally goin to the ka) to the all the altinator and starter wires(that came with the motor, they were just cut) and i matched up all the colors and im thinking some are different. There were some wires that came from the ka that didn't match up and i couldn't put them anywhere. What do i do. I dont kno where to go please help |
![]() Join Date: Apr 2008
![]() ![]() ![]() Feedback Score: 0 reviews
Is there any way you can locate a new or used lower harness from either an SR or KA?
The Alternator only has 3 items going to it - 1 eyelet for power. 1 ground strap. and 1 plug. The Starter uses 1 eyelet for power and a spade for ground. Advise you to also check your fuses to see if you are burning anything up. The clicking sound is a relay. I'd check to see what relay you are activating. Be careful whenever you wire anything up and then decide to put power through it... you could fry everything if it is done improperly.
1993 AW Mazda RX-7 1997 Nissan Silvia |
Yea i might have to go jank one from a different s13 in a junkyard.
Its just it looked like my wires were goin to the right place, but maybe their wrong. And what fuse do you think it could be, cus i checked them and they look good. Is there any fuse in the car it could be? Or is it the just one in the main fuse/relay box in the engine bay? |
Fuses to check would be the main EGI fuse, 12V fuse, ECU fuse, IGN Fuse, Starter fuse. Basically anything related to the starting of the car. Check fuses inside the car and in the engine bay.
