![]() Here's my setup:
stock sr redtop fmic mbc set @10psi 255lph walboro fuel pump z32 fuel filter greddy type rs bov (recir) safcII(just for monitoring purposes not hooked up to maf) 3" turbo back exhaust I did an oil change in which I had my battery disconnected for 24hrs. The next day, after letting it warm up, I take it out for a spin and I get bogging/hesistation in first but boost fine in all other gears. My boost gauge doesn't even hit 5psi in first gear in all other gears i can hit 10psi. check for ecu codes nothing but 55. anyone have any suggestions? things I've checked timing set @ 15btdc boost & vacuum leaks tps set .5vdc at the ecu cts iacv |
