Old 09-02-2008, 02:16 AM   #1
Boostin on you
Boostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymore
s14 best way to remove interior adhesive
Im stitch welding my chasis and was wondering what the best way to remove the interior/engine bay adhesive.
I was thinking some type of stripper but Im not sure what kind.
Boostin on you is offline   Reply With Quote
Old 09-02-2008, 02:19 AM   #2
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
dry ice and a mallet for sound deadening
if you're talking about glue residue you could use many different products ranging from gasoline to a citrus based cleaner like goo-gone
JRas is offline   Reply With Quote
Old 09-02-2008, 02:27 AM   #3
Boostin on you
I already removed sound deadener, it was a pain but worth it.
and yes im talking about the glue residue.
anyone else chime in on how they removed the glue residue?
Old 09-02-2008, 06:02 AM   #4
bardabe
bardabe's Avatar
put a wire wheel on your grinder and have at it, it'll do 2 things at the same time . 1 remove the glue in the seam, 2 clean up the metal.
wear a mask so you aren't breathing the dusty glue crud
Review Thread
bardabe is offline   Reply With Quote
Old 09-02-2008, 06:33 AM   #5
Boostin on you
sounds like a better option, time to go to Harbor freight =)
