Old 09-13-2008, 10:56 PM   #1
CoreyS13
CoreyS13 is on the path to ruinCoreyS13 is on the path to ruinCoreyS13 is on the path to ruin
Why Won't You Budge?!
Okay I am removing the exhaust from the exhaust manifold and 2 of the 3 nuts came off like butter then the last one won't budge. I sprayed it with multiple types of sprays such as wd40, liquid wrench and another one the name slips from my head. Getting up into that area isn't exactly the most roomy of places either so does anyone have any ideas that wont damage the studs on the exhaust manifold.
EDIT: I've been using an impact wrench.
CoreyS13 is offline   Reply With Quote
Old 09-13-2008, 11:05 PM   #2
drftem
drftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the roughdrftem is a jewel in the rough
just wrech it off and if the stud comes out then rethread it in it should be just like a head stud.
Team Thurs. Knights
drftem is offline   Reply With Quote
Old 09-13-2008, 11:06 PM   #3
DisEpyon
DisEpyon's Avatar
DisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to behold
Send a message via AIM to DisEpyon
try using a torch to heat it up, remember when metal gets heated up it expands.
DisEpyon is offline   Reply With Quote
Old 09-13-2008, 11:20 PM   #4
CoreyS13
Hmm I never even thought about trying out a torch, may be a very tight squeeze though.
I'm pullin the engine and selling it to make room for the new engine that will be going in. I don't want to damage anything like that so I can get some decent money on this to put towards the project.
Old 09-13-2008, 11:26 PM   #5
sidewayz240
sidewayz240's Avatar
sidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nice
yup, your gunna need to heat it up. Also dont be afraid to use force, if you break the stud, oh well. Just drill it out and put a bolt in its place.
-Trevor
sidewayz240 is offline   Reply With Quote
Old 09-13-2008, 11:27 PM   #6
Sileighty_85
Sileighty_85's Avatar
Try and get a breaker bar on it
You can put more torque on it then the Impact Gun
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-13-2008, 11:28 PM   #7
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
torches are awesome. Heat that fucker up red hot, get a breaker bar on it, and have at it...
It works for me 9 out of 10 times.
SexPanda is offline   Reply With Quote
Old 09-13-2008, 11:43 PM   #8
SidewayZ-s14
SidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enoughSidewayZ-s14 will become famous soon enough
Agreed. Best way to get at it is to heat it up with a torch. Good Luck
SidewayZ-s14 is offline   Reply With Quote
Old 09-13-2008, 11:53 PM   #9
CoreyS13
I'll pick up a torch tomorrow then after I get it red hot I'll toss the impact on and hopefully it'll melt off like butter. Grr this is the only thing holding me back from pullin the darn engine tomorrow If it doesn't come off I may shed a tear.
Old 09-14-2008, 12:49 AM   #10
DisEpyon
DisEpyon's Avatar
A regular propane torch wont get it red hot, but should get it hot enough to make the nut expand enough to twist off. did you try using PBP blaster? that stuff really helps. what you should do is put that stuff on and leave it for about 30 min then try to wrench it off, if not, then use the torch, if that doesnt work, then put the PBP blaster on then wait like 5 mins then heat that stuff up along with the nut.
most importantly, be careful
Old 09-14-2008, 01:44 AM   #11
Boostin on you
Boostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymoreBoostin on you is not welcome here anymore
grind it off.
Boostin on you is offline   Reply With Quote
Old 09-14-2008, 03:14 AM   #12
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
it will suck it it snaps off. my old s14 was a bit rusty on the cat/exhaust flange. one bolt ended up snapping. i had to drill that out in a 20 degree garage, took forever. so try your best not to have anything like that happen lol. good luck.
SlideWell is offline   Reply With Quote
Old 09-14-2008, 09:37 AM   #13
CoreyS13
What is PBP Blaster? I am unfamiliar with that.
Old 09-14-2008, 09:49 AM   #14
Sileighty_85
He means PB-Blaster
its like kick ass WD-40
後輪駆動車1番
1986 SR86 - 200ish
Old 09-14-2008, 07:06 PM   #15
CoreyS13
Thanks guys, I used a propane torch until glowing red then used a breaker bar and it came right off!
Old 09-14-2008, 07:25 PM   #16
silviaguy240
silviaguy240's Avatar
was it the one closest to the motor? i snapped mine with a breaker bar.
Old 09-14-2008, 11:03 PM   #17
CoreyS13
It was the sucker furthest away from the motor and in the most awkward position of the 3. I was actually expecting a bad outcome of the situation but sometimes after so many things going wrong somethings gotta go right.
