Old 09-14-2008, 05:08 PM   #1
seanc
seanc is an unknown quantity at this point
sr20det starting problem
ok swapping in a s13 sr in a s13 calum ecu 650cc injectors and z32 maf only things that arent stock. ok the car would start then die. so i decided to pull off the fuel rail which has pressure, then i pulled off the coil packs and then the CAS now when i first start to rotate the CAS the 4 injectors will fire a short small squirt of fuel then after that if you continue to rotate the CAS, like the engine was running, no fuel squirts again, although all the coil packs fire at the appopriate time. then if you stop rotating and start again the injectors will give a small squirt. all injectors have 12v and they get the ground signal at first then nothing. all injector signal wires are ok, checked with a ohm meter. any ideas? thanks!
Looking For A Holset HX 35
seanc is offline   Reply With Quote
Old 09-14-2008, 11:19 PM   #2
FRoSt415
FRoSt415's Avatar
FRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura about
Send a message via AIM to FRoSt415
could it be that the ECU is not Tuned for the z32 maf? if its not that might be the problem.i would recheck maf wires to make sure their right also. but it doesnt really sound like thats your problem so you ahve fuel pressure in the mainn line going to the fuelrail? check the fuel pump if u havent changed it and the fuel filter and make sure its not clogged.
FRoSt415 is offline   Reply With Quote
