Old 09-22-2008, 06:49 PM   #1
sbc
sbc is making a name for him/her selfsbc is making a name for him/her self
Is this thing important?
It appears to be a little brass piece. I think it came out of my fuel line just before the fuel pressure regulator. I'm guessing its there to create more pressure? Is it necessary? The engine is an SR by the way.
sbc is offline   Reply With Quote
Old 09-22-2008, 06:51 PM   #2
Ben G
Ben G's Avatar
Ben G is an unknown quantity at this point
what happens when you start the car with out it
Ben G is offline   Reply With Quote
Old 09-22-2008, 06:55 PM   #3
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Probably a bushing or something to keep the regulator from leaking?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 09-22-2008, 08:40 PM   #4
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
I cant tell from the pic but if it is indeed copper then it is what they call a crush washer that keeps your car from leaking fuel on your fittings. Ill search for a pic i dont know where these go on sr20's
WangonwWarrior is offline   Reply With Quote
Old 09-22-2008, 08:41 PM   #5
WangonwWarrior
Here it is, it goes on the bolt just like an ordinary washer but it gives it a seal. On the top hose in the pic on the far left a bolt runs through that line to connect it to your fuel system, put one on each side of the line when you put the bolt in. Dont loose it these are hard to find in metric. Hope this helps
Old 09-22-2008, 09:07 PM   #6
sbc
The car runs without it but I have had a recurring problem with the car running rich and I was thinking maybe too much fuel is coming through.
Wangon, that is not the same thing, sorry about the pic not showing the profile of it.
Here is a better look.
[IMG] [/IMG]
Old 09-23-2008, 07:19 PM   #7
WangonwWarrior
Ohh that does look like some type of regulater. Maybe you insert it to your fuel line or somthing i dunno
