Old 09-23-2008, 07:17 PM   #1
jinesz32
jinesz32's Avatar
jinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to beholdjinesz32 is a splendid one to behold
Send a message via AIM to jinesz32
bogging problems ka24de.
okay well recently my car started bogging RANDOMLY, i don't know if bogging is the right word to use for it, but i'll explain it, say i'm in 5th gear cruising at like 65, and out of no where while my foot on the gas hasn't moved yet, it would see as if the engine wants to turn off and i have no power going to the throttle, anyone know any solutions? stock ka24de.
same thing happens to my friends ka-t.
i thought it was my nasty fuel filter so i replaced that, and i thought it was vacc leaks so i pluged up all my vac lines but the same problem occured, any help would be appreciate. thanks (:
jinesz32 is offline   Reply With Quote
Old 09-23-2008, 07:42 PM   #2
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
u try replacing Cap & Rotor?
gijoe69 is offline   Reply With Quote
Old 09-23-2008, 08:18 PM   #3
jinesz32
jinesz32's Avatar
nope not yet, kinda broke right now just wondering what the heck is going on with the car, just wanna get a clue in how much im gonna need to fix it.
thanks for the reply. (:
Old 09-23-2008, 08:27 PM   #4
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Your going to spend alot of time diagnosing this. Its best if you grab a manual, and pull the codes. Go from there.
Could be the timing getting pulled from either the KS, Invalid readings from the IAT could also mean your CTS is going. You could get a code for the intake air temp, but really could mean your CTS is going. Could be the coolant is boiling, or you have air bubbles. Could be the EGR.
Bigsyke is offline   Reply With Quote
Old 09-25-2008, 02:29 PM   #5
jinesz32
jinesz32's Avatar
damn, lol. i guess i'll get it scanned soon for codes. blaaaa.
thanks for the response. (:
Old 09-25-2008, 02:36 PM   #6
JDM671
JDM671's Avatar
Trader Rating: (37)
JDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfectionJDM671 is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to JDM671
maf? mine bogs and my problem was the maf going bad. So idk you can check that too.
Touke <3
JDM671 is offline   Reply With Quote
Old 09-25-2008, 02:39 PM   #7
CoreyS13
CoreyS13 is on the path to ruinCoreyS13 is on the path to ruinCoreyS13 is on the path to ruin
Same problem with mine and it turned out to be the fuel pump shorted out. Simple solution was pulling the engine and getting it ready for the swap.
CoreyS13 is offline   Reply With Quote
Old 09-27-2008, 04:48 PM   #8
jinesz32
jinesz32's Avatar
ill check that out, thanks for the replies guys.
