Old 09-24-2008, 06:44 PM   #1
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
KA Low Oil Pressure
yo my ka-t has been having some low oil pressure problems, like its fine until it warms up all the way anywhere between 50-75psi then once its warm it works its way down to 25psi at 3,000 rpms in 3rd gear. i replaced the oil pump about 2,000 miles ago hoping to fix the issue, its an oem nissan full kit. i changed the oil to 10w30, and changed the oil filter as well. i cant figure it out, any insight. btw the motor was just rebuilt about 5000 miles ago....
Slip Gypsies Blog
not sure if you realize this
Old 09-24-2008, 06:47 PM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
do you have a dented oil pan? maybe the oil pickup is pressed up against the bottom of the oil pan restricting flow.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 09-24-2008, 06:50 PM   #3
punxva
punxva's Avatar
Trader Rating: (31)
it is a little dented but not too bad, i'll take a picture tomorrow morning before work, thats the only thing i can actually think that would cause it... but at the same time wouldnt it do it all the time, not just when warmed up?
Slip Gypsies Blog
Old 09-24-2008, 06:53 PM   #4
SoguRacing
SoguRacing's Avatar
get a new oil pan anyways, especially if it the dent is in the middle or near the middle. a little dent can cause a big restriction. thats how my sr went out. spun 2 rod bearings.
Old 09-27-2008, 09:25 PM   #5
punxva
punxva's Avatar
Trader Rating: (31)
ok, is there anything else this could be other than the pan, just wondering so i can try different things, since it's a bitch to take the pan off the ka while its in the car, so i dont want to take it out and fix it if it really isnt the problem....
Slip Gypsies Blog
