Old 10-02-2008, 05:54 PM   #1
obarrera
obarrera's Avatar
obarrera is an unknown quantity at this point
Sportmax 962 Flush look possible?
I want my wheels to look flush but im not sure if it's possible with my wheels, I have sportmaxes, I believe the sizes are:
BACK 17x9, +35 offset 4x114.3.
FRONT 17x8, +35 offset 4x114.3.
I am getting megan racing coilovers, spacers, and rolling the fenders. I read bout spacers and some people don't reccomend them, I wanted to get 20mm or 25mm spacers, probably 25mm for back 20mm for front, now would that be too dangerous?
Please don't bash, that's why im asking before buying.lol
Also, what kind of tires would be best?
I couldn't find much info on this, seems like most people that have the flush look have work wheels or similar on there cars, and I can't afford that right now.
obarrera is offline
Old 10-02-2008, 05:57 PM   #2
cc4usmc
cc4usmc's Avatar
http://zilvia.net/f/chat/129865-whee...re-thread.html
This forum requires that you wait 120 seconds between reporting posts. Please try again in 115 seconds.
Originally Posted by s141996 View Post
is this exhaust california friendly? thnx lmk
cc4usmc is offline
Old 10-02-2008, 05:59 PM   #3
A Spec Products
A Spec Products's Avatar
- Flush is a relative term. What is "flush" to you? With a 17x8+35 / 17x9+35, I'd say you'd need at least a 15mm to be around where "flush" on stock fender S13 would be...but again, outer position of the wheel is determined by a lot of variables such as tire brand, tire size, camber, ride height, etc.
- Spacers are "safe" as long as you use them properly. Make sure you torque to proper specs, and use extended studs where necessary. A 5mm sandwich spacer is usually "safe" on stock studs, but anything larger that is a sandwich spacer should use extended studs. Bolt on spacers (that incorporate the stud into it) usually start at around 15mm, so if you're using a 15mm+ then a bolt on spacer won't require new wheel studs.
- What kind of tires would be best is a very relative question. Price wise? Performance wise? What size should you run?
I'd say if you are on a Sportmax budget, then Federal SS595 are the obvious choice (contact CITY TIRE ONLINE for a good deal)
Tire size maybe....215/45/17 all around? 215/40 F 215/45/ R? 215/45 F 235/40 R? I dunno with lack of details hard to say what would be "best."
A SPEC PRODUCTS CORP
A Spec Products is offline
Old 10-02-2008, 06:30 PM   #4
silsx13
silsx13's Avatar
Trader Rating: (34)
silsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant futuresilsx13 has a brilliant future
Feedback Score: 34 reviews
Send a message via AIM to silsx13
s13
I've been running 962s on my S13 for a long time now with this setup:
Front: 15mm spacer w/a 5mm spacer sandwiched (between the spacer and hub) and a 3mm spacer on top
Offset = +12
Tire size: 215/45/17 or 225/45/17 Federal 595RS
Rear: 15mm spacer w/a 5mm spacer sandwiched
Offset = +15
Tire size: 225/45/17 Federal 595RS
Here's a pic:
Attachment 14335
This is a "reverse" stagger where instead of the rears sticking out more than the fronts, it's the total opposite! I know it probably goes against the grain in terms of "preferred" wheel aesthetics but it's hardly noticeable unless you look really close or are really picky.
I haven't had any problems (i.e. vibration, wheel shimmy, etc.) running this wheel setup- I just check to make sure the spacers are torqued down to correct specs before and after doing a drifting event or after driving a lot of miles.
Hope that helps.
Blog: http://hartapexlife.blogspot.com/
silsx13 is offline
Old 10-02-2008, 06:44 PM   #5
Bushido
Bushido's Avatar
rule of thumb on 9j = get as close to +15 on stock fenders as you can.
Bushido is offline
Old 10-02-2008, 06:45 PM   #6
pinkarrowsnow
pinkarrowsnow's Avatar
pinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura about
big spacers i have a 20mm in the front of my 962's so it makes it +15 its pretty flush
pinkarrowsnow is offline
Old 10-02-2008, 06:49 PM   #7
TheWayItGoes909
TheWayItGoes909's Avatar
TheWayItGoes909 is an unknown quantity at this point
holy crap thats alot of spacers!
TheWayItGoes909 is offline
Old 10-03-2008, 12:00 AM   #8
obarrera
obarrera's Avatar
Awsome, thanks a lot for the info. Here is the look I want, I think the fenders are actually pulled a little instead of rolled? I want the top end of the rear tires to be inside the fender. I don't want to sit flush on the fender with no roll or pull, I want it to sit flush after the pull of the fender, sorry if it's not clear enough.lol
When I say what kind of tires would be best,
the question is what kind of tires would
give me this look ^^^
silsxs13, it looks sik man! but I do want the staggered look on mine though.
Thanks everyone for the help!
obarrera is offline
Old 10-03-2008, 12:14 AM   #9
ayuaddict
ayuaddict's Avatar
ask matej.
the only person to ever make sportmaxes look good.
old pic of his car.
ayuaddict is offline
Old 10-03-2008, 12:19 AM   #10
HyperTek
or leetheslacker, who painted his white, look way better
Keep it Classy
HyperTek is offline
Old 10-03-2008, 12:24 AM   #11
awesomenick
awesomenick's Avatar
Trader Rating: (33)
awesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfectionawesomenick is close to perfection
Feedback Score: 33 reviews
True. Matej's car was sick with those, it's still sick. I think so at least.
Sick. I just saw some old pics of his car with meshies while I was looking for that one. Weird.
awesomenick is offline
Old 10-03-2008, 12:32 AM   #12
obarrera
obarrera's Avatar
That looks friggen sik..i forgot bout that car..
I've seen leetheslacker's car too, I'll see which look I like best, I don't think leetheslacker has his fenders rolled or pulled, does he?
obarrera is offline
Old 10-03-2008, 12:48 AM   #13
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
wow that does look good.
kinda sucks about the 8s though, but i would run a 205/40 up front and a 215/40 rear. the 205s will stretch nicely over 9s, but then you'd need like 195s up front and thats gay. then, i would get a 30mil up front and a 20mil rear. and its just as safe as anyone else's stretch/spacers.
call up part shop max. they usually stock spacers. (they're in sd)
Marcus is offline
Old 10-03-2008, 12:57 AM   #14
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
i had 17x9 +35 on my s13 before
i went with 225/45 for the tires along with 25mm spacers all around.
rolled rear fenders, 20mm fender on the front
this should give you an idea
markyboi is offline
Old 10-03-2008, 01:19 AM   #15
obarrera
obarrera's Avatar
Marcus, where in SD is this place at, do you have there info?
markyboi, your car looks sick, do you plan on dropping it a little more? some more negative camber would look cool
obarrera is offline
Old 10-03-2008, 01:24 AM   #16
markyboi
lol..that was my car 2 years ago..
it looks like this now
markyboi is offline
Old 10-03-2008, 02:15 AM   #17
obarrera
obarrera's Avatar
Nice nice, can't wait to get my coilovers n everything, 25 more days to go. I will post pics of my car when I finish my set up.
obarrera is offline
Old 10-03-2008, 02:16 AM   #18
blanco
blanco's Avatar
blanco is an unknown quantity at this point
heres my setup.
17 x 9 all around
30mm spacers all around
215 45 all around
and here is before it was lowered
blanco is offline
Old 10-03-2008, 08:33 AM   #19
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Looks great, props to you for that.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline
Old 10-03-2008, 08:56 AM   #20
Bushido
Bushido's Avatar
i don't care that these wheels are heavy as shit and low quality.
they are a classic 5 spoke design that looks great when rocked properly, as matej and blanco have shown.
Bushido is offline
Old 10-03-2008, 09:21 AM   #21
1slowS13
1slowS13's Avatar
1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice1slowS13 is just really nice
i actually got to fit a 17x9 +35 on the front of my s13 just with a 215/45, its a tad bit high but good for daily driving. ill take a picture once i find my camera
1slowS13 is offline
Old 10-03-2008, 09:31 AM   #22
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
Damn, blanco's car looks like my coupe in hatch form. Oh yeah, I have some weaksauce Spec V's on mine as well.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline
Old 10-03-2008, 09:31 AM   #23
240trainee
240trainee's Avatar
Yea, I mean, why the fuck not.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 10-03-2008, 09:39 AM   #24
1slowS13
1slowS13's Avatar
i thought there were a whole grip of people not being able to fit them because of clearance issues with their coils/struts
1slowS13 is offline
Old 10-03-2008, 09:43 AM   #25
1slowS13
1slowS13's Avatar
only picture i have.. this is actually 006 series
1slowS13 is offline
Old 10-03-2008, 09:51 AM   #26
Marcus
Marcus's Avatar
Trader Rating: (18)
word. they look sick like that. and at that point the brand of the wheel becomes secondary to its fitment. if it looks hard as hell, people wont notice right away that they're 962s.
op: part shop max is in miramar..poweredbymax.net
Marcus is offline
Old 10-03-2008, 11:15 AM   #27
GhettoIced-t
GhettoIced-t's Avatar
GhettoIced-t is an unknown quantity at this point
Yeah i thought the same way, and if i drift into a curb i could replace all 4 for the cost of just one Work Wheel.
I rock 17x9's +35 20mm in spacers up front and 30mm's in the rear with a roll and pull...on an s13
they have an aggresive look and the uninitiated think i paid big bills for them
GhettoIced-t is offline
Old 10-03-2008, 11:46 AM   #28
obarrera
obarrera's Avatar
Sick, I didn't think there were people with these kinda set ups, Ghettoiced-t you got some pics?
I don't care bout heaviness right now either, I only use my car to cruise around anyway....for now. So just as long it looks good
blanco, nice dude!
obarrera is offline
Old 10-03-2008, 05:11 PM   #29
Leetheslacker
Leetheslacker's Avatar
Leetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond reputeLeetheslacker has a reputation beyond repute
Originally Posted by blanco View Post
heres my setup.
17 x 9 all around
215 45 all around
your car and my car should be friends.
17x9 all around.
1inch spacers all around
215/40 front, 225/45 rear.
rolled front, rolled and slight newspaper pull in the rear.
rubs the letters off the rear.
Leetheslacker is offline
Old 10-03-2008, 05:28 PM   #30
S13shaka
S13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymoreS13shaka is not welcome here anymore
I am an idiot who can't understand when a moderator deletes my posts and leaves the warning "don't start this shit"
Please laugh and make fun of me
S13shaka is offline
