Old 10-02-2008, 07:22 PM   #1
EDz s14
EDz s14's Avatar
EDz s14 will become famous soon enoughEDz s14 will become famous soon enoughEDz s14 will become famous soon enough
Coilovers not low enough
I have the Tein HAs, old model of the SS. The height is adjusted from the spring preload or droop. But I am maxed out on the spring droop and I want to go lower about an inch. Is there a way that I can do this? I asked Tein about removing the helper springs because when they sit flat it is about an inch, but the told me not to. Will shorter coil spring drop the car? I really dont want to change coilovers because I like how these ride.
EDz s14 is offline   Reply With Quote
Old 10-02-2008, 07:23 PM   #2
iHeartTheTouge
iHeartTheTouge's Avatar
iHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfectioniHeartTheTouge is close to perfection
i dont know much about tein, but i dont think they're known for going real low. if your looking for low Stance and Powered by Max are the way to go. they arent too expensive either
Slide 'n Hide
-'72 240z LS1 project
iHeartTheTouge is offline   Reply With Quote
Old 10-02-2008, 11:32 PM   #3
hotlavaflow
hotlavaflow's Avatar
hotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to beholdhotlavaflow is a splendid one to behold
Send a message via Yahoo to hotlavaflow
My Teins don't drop me as low as I wanna be either (in the front, the rear can slam) I have HKS springs on them and I'm only 1/2" away from niceness so I'm just going to remove the bottom collar.
hotlavaflow is offline   Reply With Quote
Old 10-02-2008, 11:55 PM   #4
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
the tein flex will go LOW
huffandpuff00 is offline   Reply With Quote
Old 10-03-2008, 08:15 PM   #5
EDz s14
EDz s14's Avatar
hotlavaflow- do your HKS springs make a difference in height than the tein springs or are they the same height?
Old 10-03-2008, 08:19 PM   #6
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
putting shorter springs on those dampers will screw them up....they are designed to have a certain stroke or whatever, so when you shorten the spring, you are fundamentally changing how that shock is gonna work
Daily driven
jspaeth is offline   Reply With Quote
Old 10-03-2008, 08:21 PM   #7
sultan
sultan's Avatar
sultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enoughsultan will become famous soon enough
my tanabes had helper springs and they didn't go low enough, removed the helpers and i have 2" of spring droop. no problems, still wish it could go lower
sultan is offline   Reply With Quote
Old 10-03-2008, 08:35 PM   #8
Driven08
Trader Rating: (354)
Driven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfectionDriven08 is close to perfection
Feedback Score: 354 reviews
I have Tein flex coilovers but I have like 1.5 inches droop in the rear/ I had to do that in order to tuck a little bit of my tire. Thats only in the rear.Should i buy new rear springs?Longer ones?
Driven08 is offline   Reply With Quote
Old 10-03-2008, 08:46 PM   #9
Ben G
Ben G's Avatar
Ben G is an unknown quantity at this point
tien ha's just don't go as low as other coilovers a lot of people seem to have problems with that
Ben G is offline   Reply With Quote
Old 10-04-2008, 12:37 AM   #10
hotlavaflow
Actually the HKS springs are longer. Supposed to increase ride quality and handling on really low rides. It's a bitch getting them on there.
Old 10-04-2008, 09:09 AM   #11
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
it will be moving on a different range, and most likely that range will or come close to bottoming out.
I would be more concerned about the suspension geometry that is being fucked up from slamming the car anyhow. Many of the suspension systems that have been designed can only lower your car so much for a reason. Nismo products give you a good idea of how low you can go without dropping the roll center into the ground. Unless you get adjustable control arms to fix the geometry, the lower you go after a certain point, the crappier your car will handle believe it or not.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 10-04-2008, 09:40 AM   #12
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Why does everyone want their car slammed? I don't get it. If you remove the helper springs the springs will un-seat anytime the suspension becomes un-weighted, which will most likely be pretty often if you are already as low as they can go. Shorter springs will do the same thing. You will also lose precious suspension travel, especially in the front, and that "ride" that you like so much will go to shit because you will bottom the shocks on every bump. Bottoming the shocks wears them out faster. You are trying to do something that the coils were not designed to do. If you really have a hard-on to go lower you should get a set of coils that are designed to be able to go lower.
Old 10-04-2008, 02:59 PM   #13
EDz s14
EDz s14's Avatar
haha my car is not even close to being slammed, the 1in drop that I want to do will only tuck the tire in about 5mm. I just want to know if there are other alternatives that I can do, but I guess it will lead to other problems. So........ anybody want to trade coilovers?
Old 10-04-2008, 03:15 PM   #14
FRpilot
FRpilot's Avatar
like airbags!! woot
FRpilot is offline   Reply With Quote
Old 10-04-2008, 03:30 PM   #15
sileighty83
sileighty83's Avatar
sileighty83 is just really nicesileighty83 is just really nicesileighty83 is just really nicesileighty83 is just really nicesileighty83 is just really nicesileighty83 is just really nicesileighty83 is just really nicesileighty83 is just really nicesileighty83 is just really nicesileighty83 is just really nice
Send a message via AIM to sileighty83
I have the Tein HE drift specs and they are maxed out as well...not as low as i would want either...but none the less great suspension
sileighty83 is offline   Reply With Quote
Old 10-04-2008, 06:07 PM   #16
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
Get a fatter girlfriend.
jk.. is it the front or the rear that you want lower? I'm going to guess the fronts.
The HAs didn't come with camber plates on the front, so putting a set of camber plates will allow them to be lower since the plates usually have a thinner profile than the stock upper strut bearing deal. Give that a try.
Chernobyl is offline   Reply With Quote
