Old 11-27-2001, 09:49 AM   #1
Guest
Posts: n/a
Is it easy to put on the apex-i N1 Dual catback system, or will I need to bring it somewhere?  Will I need any out of the ordinary tools.
Love,
Chance
Old 11-27-2001, 10:02 AM   #2
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
yes u should be able to, but there is a problem. getting the old one off...... most of the time, it is hard to get off the seized bolts on the old exhuast. if u have a flame torch it would help to heat the bolt and then it might be easier to turn it with your big socket wrench and a wrench that fits over the nut. when u r on the ground at home, it is hard to get leverage to take off the stubborn nut and bolts.... u can always give it a try. also it is easier to cut off the old one before u put on the new one (depends on do u wanna keep the old one)
u need a big flat head screw driver and a big channel plyer (to take the exhuast off the hangers)
either a 12,13, or 14 mm socket wrench and another one for the bolt....
maybe a hack saw or saw-zaw to cut off the old exhuast
drifterx is offline   Reply With Quote
Old 11-27-2001, 10:32 AM   #3
Guest
Posts: n/a
well i've got a 98, so do you think the bolt will come off easier since it's not as old and rusty as others?
Old 11-27-2001, 11:07 AM   #4
alchemist
alchemist is an unknown quantity at this point
it will still be siezed,  i had that happen only after a few months.  it can be done, but will be hard....when in doubt buy a dremel type tool,  it came in handy with my exhaust repair, and many other projects.  The dremel can cut bolts, cut pipe, hangers, etc
alchemist is offline   Reply With Quote
Old 11-27-2001, 12:49 PM   #5
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
Also get some good quality pentrating oil and throughly spray the #### outta them bolts and let it sit for 15 minutes or so before you tackle it.  Maybe have the other stuff as a back up though.
HippoSleek is offline   Reply With Quote
Old 11-27-2001, 02:10 PM   #6
Chokudori
Chokudori is an unknown quantity at this point
From my experience, I'd say use alot of WD-40 and get a ramp or a bunch of bricks so you could ride your car onto it. Use butter to loosen the rubber hangers.
Once you notice that you're stripping the bolt, just stop. Take it to a muffer shop.
Chokudori is offline   Reply With Quote
Old 11-27-2001, 03:54 PM   #7
drifterx
drifterx's Avatar
also my advice before u install your new one.... put anti-seize on the bolts..... it is a silver thing u rub over the bolt before u put it on
Old 11-28-2001, 01:58 PM   #8
Krunko
Krunko is on a distinguished road
Send a message via ICQ to Krunko Send a message via AIM to Krunko
can I get anti-seize at an autoparts store?
Krunko is offline   Reply With Quote
Old 11-28-2001, 02:02 PM   #9
drifterx
drifterx's Avatar
yes or at home depot....
it came in handy for a friend when he had to switch from his loud N1 to his stock
Old 11-28-2001, 02:27 PM   #10
Guest
Posts: n/a
what will the anti-seize do exactly?
Old 11-28-2001, 02:36 PM   #11
chickenmanq
chickenmanq is an unknown quantity at this point
Holds the nuts on, but also keeps them from forming rust welds.  You know when you just can't get the #### things off?  It's a good idea to put a small quantity on your spark plugs too.  Easier on the threads, and you lessen the risk of breaking them off.
chickenmanq is offline   Reply With Quote
