![]() Join Date: Nov 2003
1973 240z (s30)
Bought this s30 a long time ago with big plans, LS1, coilovers, big brakes, blah blah. Have a kid with another on it's way, an evo, s13, and 2 old school chopper projects going on right now. Need to sell something, so it's the s30.
![]() Car came from AZ, Pretty much no rust at all. Just some very VERY light surface rust here and there, that can be sanded right off. It's been stored inside since the day I got it. The previous owner did replace the floor panels but just pop-riveted sheet metal there. I was planning on installing Zedd Findings floor panels which are stronger than original. Zedd Findings The interior is in very good shape. The exterior is also in very good shape, just a few very small dings by the rear antenna area. I had a paintless dent remover guy look at it and he said they would come out no problem. It does have a single stage paint job that is chipping in a few spots. Being a 73 it has the craptastic Hitachi carbs. I am however including a set of SU carbs, manifold and airfilter holder with the car. Also a brand new in the box air filter. I would rebuild the carbs prior to installing though. I bought the SU carbs because the Hitachi carbs run like shit. You could rebuild and tune the Hitachi's, but what is the point, they are still crap. One of the wheels lugs has some threads messed up on it. I am including a brand new set of ARP LONG super strong wheel studs. Also a set of Muteki open ended lug nuts. Wheels bearings don't need replacing, but I figured when I was going to do the brakes and suspension I should do those. So I am including brand new wheel bearings. I am including everything I have for it, so I will just list it: Except for the battery, these items below are all NOT installed. Used SU carbs, manifold, and air filter holder (will need a rebuild I would think) New Air filter New Battery (installed) New Front brake pads New Rear brake shoes New fuel filters (2) New ARP Long wheel lugs New Muteki silver open lug nuts New wheel bearings Located in MA. $5000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
TougeHero.com l SilviaV8forums.com |
