Old 10-05-2008, 11:28 AM   #1
slipin101
slipin101's Avatar
slipin101 has a spectacular aura aboutslipin101 has a spectacular aura aboutslipin101 has a spectacular aura aboutslipin101 has a spectacular aura aboutslipin101 has a spectacular aura aboutslipin101 has a spectacular aura about
Send a message via Yahoo to slipin101
sohc to dohc HELP!!
first time doing a swap my self. i got the motor put in but no spark , .... so if any one is willing to come over and help figure out the problem let me know..ill pay for your time. need this car running soon.... i also have 2 clips that i have no idea where they go to.
slipin101 is offline   Reply With Quote
Old 10-05-2008, 11:29 AM   #2
slipin101
slipin101's Avatar
Old 10-05-2008, 11:50 AM   #3
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
i know for a fact that the last one has nothing to do with you not getting spark. i believe thats a sensor that goes somewhere by the intake manifold (on top)
R@ddy is offline   Reply With Quote
Old 10-05-2008, 12:10 PM   #4
slipin101
slipin101's Avatar
also does it matter if the dash clip is not connected(next to the ECU)? also im using the alternator from a sohc withe the wiring harness. does thaat matter?
Old 10-05-2008, 04:59 PM   #5
Z_Spool
Z_Spool's Avatar
Z_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura about
Are you using the SOHC ignition coil? (you need the DOHC as it has an extra plug vs. the SOHC)
Z_Spool is offline   Reply With Quote
Old 10-05-2008, 05:23 PM   #6
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
use the wire colors and search through the wiring diagrams in FSM. u can alwayz trace the unknown plugs that way. GL
s13drob is offline   Reply With Quote
Old 10-05-2008, 07:28 PM   #7
projectRDM
projectRDM's Avatar
What color are the wires in those two plugs?
The dash plug has the start signal wire (orange) so it has to be connected for the ECU to read it.
FORMERLY R240NA
Old 10-06-2008, 08:33 AM   #8
slipin101
slipin101's Avatar
the clip near the starter is a 2 wire clip. with thick wrapin. the other is next to the fuse box 4 wire clip. theres 3 clips already plugged to the fuse and 1 to to th ALT. i dont remember the colors right now
Old 10-06-2008, 09:14 AM   #9
projectRDM
projectRDM's Avatar
Can't help you without that info.
FORMERLY R240NA
Old 10-06-2008, 09:18 AM   #10
slipin101
slipin101's Avatar
how about there all part of the lower tranny harness.
Old 10-06-2008, 09:32 AM   #11
projectRDM
projectRDM's Avatar
We know that. The 2pin looks like the alternator plug.
FORMERLY R240NA
Old 10-08-2008, 11:42 AM   #12
slipin101
slipin101's Avatar
FACK!! i cant find my camera....does it matter if im useing the sohc lower harness on the dohc? and sohc alt
Old 10-08-2008, 11:52 AM   #13
projectRDM
projectRDM's Avatar
What color are the wires? That's all we need to know.
If you're using a SOHC lower harness the 2pin plug is probably a pair of brown wires, that's the power steering pressure switch. Not needed.
FORMERLY R240NA
