Old 10-05-2008, 09:21 PM   #1
Tensor187x
Tensor187x has a little shameless behavior in the past
Car wont start!
Hey guys, i'll try my best to explain my situation!
My car doesnt start after i unpluged my turbo timer! I took out the turbo timer as well as the harness, and connected everything back up as it would be without the TT. Well, i did notice that the turbo timer had two long wires coming out of it, that ran all the way to the ECU connection (the long blue plug that connects on the ECU). Those two wires were spliced into some wires coming out of the ECU. Well, after this my car wont start. I tried finding which two wires were spliced to which, and i can't find them! I know it's not my starter because i took a positive cable and put one end on the start and the other end on the + of the battery and the car started fine! When i put the key in the ignition and turn it all the way on, just the gauge cluster lights up, like it should but the car WILL NOT even turn. It doesnt even make an effort to. Nothing. I need all the help i can get!
Thank you!
Tensor187x is offline   Reply With Quote
Old 10-05-2008, 10:18 PM   #2
d-magic
d-magic is an unknown quantity at this point
Does your car have alarm system? Maybe someone figured out a way to make that turbo timer work with alarm...maybe.?.
d-magic is offline   Reply With Quote
Old 10-05-2008, 10:31 PM   #3
Tensor187x
Yes, my car has TWO alarm systems! The previous owner had two alarms systems put in there, for who knows what reason. I'm thinking the same thing. I just want to rip the systems out.
Old 10-06-2008, 05:10 PM   #4
d-magic
you may just have to keep running the adapter harness or may just have to find out what that dude spliced that 6th wire too. I had to find a 6 pin harness on ebay that would work for my greddy turbo timer.
