power fc help
When i get the car running it wants to stall so i have to hit the gas to keep it going. If i go into the sensor check IGN, ECC, and FP are highlighted. Asuming FP means fuel pump why would this be highlighted how would the car run if the fuel pump werent working properly? what are some common problems i should be looking for to fix these 3 things?
Those highlights are normal. It's just saying its 'on'.
Ran fine with stock ecu? Mods? L-Jetro? D-Jetro? Here is my car on the dyno sensor status: http://www.quickesthosting.com/~spirit/dyno.avi
Ahh ic. im a noob with power fc i thought highlighted meant there was an issue. I have all the same things checked as you so i guess my idling issues are related to something else. It could be many things really, its a built motor and this is like the 3rd time ive started it I need to check for vacuum leaks.
