![]() Join Date: Jan 2003
back end jumping around on bumps
some lady hit me in the rear passenger side of my car, and bent ruca. i replaced it and it fixed the wheel caster almost completely, but whenever i go over bumps the back jumps to the left a little. any ideas? i hope its not a twisted frame. i looked at it and it only looked like the ruca got bent. any ideas on fixes? other then goin to alignment shop?
1991 240sx se red w/ big #$* dent in it!! 5 speed injen cai apexi n1 dual unorthadox pulley set oh yeah and a blown motor |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
go get an alignemt. did you get one after you changed the bent rod? if not then you should. that's probably why.
you can find shops that'll do it for like 40 bucks |
New Title
What's a ruca?
![]() It didn't bend what ever it attaches to did it? Alignment is always the easiest and cheapest troubleshooting step when solving handling problems...next to a visual inspection anyway.
#6 |
errr this is gettin crappy. some of the problem was 2 loose lug nuts. had to replace one of the lug studs cuz it got stripped, and i broke the other one. the one that got stripped out before is stripped again. im goin to go replace them again and get an alignment.
#7 | |
#8 |
I had the same problem with the tail coming out.
Push down hard on the boot of the car and then let go. The car should bounce back up once and come to a halt. If it continues to bounce up and down, you're in need of new shocks. |
#9 |
Sounds like the shocks got damaged. It shouldn't bounce like that and that is exactly what will happen if they are bad. You sure don't want the back of the car to try to catch up with the front of the car unless you are doing it intentionally.
