Tein HA's w/ Cusco pillow ball mounts
Hi guys,
I started fitting some Tein HA Coilovers and Cusco Camber Plates to my RS13 today and I seem to have ran into a problem that I had never anticipated.. The Coilovers and the Camber Plates came together as one peice, so I proceeded to pull the old strut off and went about fitting the new unit. I think the coilover is at its lowest setting, as the coilover was alot shorter than the original strut, to make life easier, I used a jack under the lower arm to hold it up to a nice hieght while I attached the Camber Plate Top Mount bolts and then bolted the shock to the hubs... The Coilover was installed and tightened up. As I wound the small jack down, to remove it from under the lower arm it had previously been holding up, i noticed that the shock was coming down at the same rate as the jack. I looked up at the Pillow Ball mount and it was no longer attached to the Camber Plate.. If the car was on its wheels with the coilovers, the Pillow Ball mount would stay in its proper posistion, obviously because the cars wieght will prevent it from dropping out of the bottom of the Camber Plate, but if you were to jack the car up or to jump/extend the shock then it would surely fall out of the Camber Plate mount.. Cant be right, can it? So, anyways here are some picture to try and explain all of that a little better.. ![]() ![]() ![]() Is this how they are supposed to be? Why do they fall away from the Camber Plates? Is this how anyone else's Teins are? Any help will be greatly appreciated, as I am totally confused ![]() ![]() Thanks Ade |
