![]() Join Date: Oct 2008
Compression Test
I ran a compression test on my rebuilt sr and got some weird results:
Thanks Last edited by slamed_s13; 10-16-2008 at 01:32 PM.. |
![]() Join Date: Dec 2006
Brand new is 156 psi
Average is 150 Minimum is 139ish? So yeah.....130 is not good Warm up engine Pull all the plugs put a teaspoon oil in each cylinder and try again @ WOT If the numbers shoot up when the oil is added then your piston rings EDIT: Oh i see you replaced the rings, break it in so the rings will seat Did you bore and hone the cylinders?? or just replace the piston rings in the stock bore? For the break in there are many ways to do it just figuring out which one is "right" cuz there are so many ppl that contradict how to do it. Me I just stayed low-med RPM's staying out of boost for 500miles
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#5 |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
how to do a compression test:
1 remove plugs 2 install gauge 3 disconnect ignition/fuel..one or the other..or both 4 prop open throttle body 100 percent 5 crank engine over 6 times while "noting" the first puff which should be at least 50 percent of the total psi...and the final puff on the gauge. Ex. 75psi would be 50 percent of 150psi of the final puff. 6 repeat for each cylinder and all final puffs should be within 10 percent of eachother. If not then you have a problem. On a rebuild engine your compression will be low at first until the rings seat. I wouldnt worry though i did my compression with 100 miles on a rebuild and my numbers were 155,160,155,155 with all other numbers within spec. s13 SR
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
#6 |
i dont agree on waiting for 6 ticks for each cylinder, as practices vary between each person you also cant 100% compare the result either... (kinda like dyno numbers, go figure hehe).
best practice is go ABOUT 6 ticks but can be more, basically wait until it tops off. first time i had my mechanic do a compression test it had semi low results at high 130's to low 140's. i was quite disappointed. then mechanic told me he only allowed 5 or 6 ticks because he felt it was "good enough". i made him go until it leveled off (about 8 ticks) and the results were high 140's to low 150's... MUCh better. |
#7 |
i disagree with your answer. it shouldn't take that many "ticks" before you reach full compression on a warmed up engine. I actually did 5 ticks on my car and the numbers should be the same because the engines are the same. perhaps going with 8 ticks is giving you a false reading and a false perception that your engine is healthier than it actually is.
#8 |
Thanks for the info guys.
I just ran another compression test and all of them showed 130psi. Like I said, I just replaced the pistons and rings with stock boaring (for the first time, I'm so pround of myself, only 19 ![]() |
#9 |
well thats probably one reason causing low compression
Your never suppose to just install rings on and old engine like that Over time the cylinders walls become uneven like / \ or \ / you need to bore and hone to make them look like this | | just beause you still see the cross hatch doesnt mean they walls are still good.
#10 |
#12 |
You bore and hone the cylinders also having to buy oversized pistons and rings that will fit the new bore
#13 | |
Yeah that's what I thought.
#14 | |
there is a piston/wall clearance |
#15 |
SoguRacing ..... I have to flatly disagree. not because 8 or 6 is correct. simply theres too many variables to say what is correct. most compression tests are not meant to compare one result to another. the numbers vary HUGELY depending on operating temp, outside temp, quality of the tester etc.
for example How to do a compression test on your engine: 240sx Articles: Nissan Forums / Infiniti Forums - NICOclub they say seven... you say 6, nissan says until it "levels off".... so whos right? no one is.....except draining your battery, 8 ticks or 80 ticks its irrelevant. a seal around the pistons will hold a specific amount and thats it. its not going to hold more so stating 8 ticks instead of 6 is giving you false positive impression is crazy. compression test is to get a rough idea of it's health, nothing more. not a pissing contest of who has a healthier motor |
