Old 10-18-2008, 12:39 PM   #1
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Sohc cut off 2500rpm
So Last night I decided that my fan shroud should come off because my fan was cutting into it. After its off all said and done a took all the lines that used to sit on top of the fan shroud and zip tied them but not tight they can still move around I did it just enough so they wont get hit by that fan and they sit right under the intake. I reassemble everything fire the motor up and It idles for like a couple of seconds and dies so then I give it gas as soon as you get to twenty five it cuts out and will not let me go any higher. Please help need to get to work =/
s13 @ fullboost is offline
Old 10-18-2008, 01:03 PM   #2
timlush
timlush's Avatar
timlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to beholdtimlush is a splendid one to behold
Send a message via AIM to timlush
Check the MAFS/wiring.
timlush is offline
Old 10-18-2008, 01:09 PM   #3
ChicagoS14
ChicagoS14's Avatar
ChicagoS14 is making a name for him/her selfChicagoS14 is making a name for him/her self
Send a message via AIM to ChicagoS14
Yeah what was stated above, usually if a car dies right away on start up and doesnt want to rev beyond 2500/3000 rpm thats the magic spot of the MAF giving trouble. If you need diagrams to help you diagnose what wires/possible vaccum lines you may need to look over then here it is:
.: Ultimate 240SX Guide :.
95 240SX 1JZGTE | SC300 2JZGE daily
www.240sxguide.com
ChicagoS14 is offline
Old 10-18-2008, 01:15 PM   #4
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
Maf, i had the same problem, or reset the ecu that helped me 2... disconnect the battery terminals over night should do that...
Ceepo is offline
Old 10-18-2008, 01:38 PM   #5
s13 @ fullboost
Thanks guys This shit is bugging me soo badly I know you guys know what I mean every s chassis owner knows what I mean haha
Old 10-18-2008, 03:13 PM   #6
s13 @ fullboost
problem solved =]
