Old 01-30-2003, 11:54 PM   #1
SilviaSR20DET
SilviaSR20DET's Avatar
SilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her selfSilviaSR20DET is making a name for him/her self
How long do clutches last?
Im just curious of how long the 240's clutches last and at what milage it should be recommended to be changed. Thanks you
SilviaSR20DET is offline   Reply With Quote
Old 01-31-2003, 01:32 AM   #2
Kamin
Kamin is an unknown quantity at this point
Send a message via ICQ to Kamin Send a message via AIM to Kamin
it all depends on how you drive. could last 20,000 miles, could last 150,000.
you will know when it needs replacing. after a hard run it will seem mushy, may make a whirring noise when partially engaged (think of cordori pants and that funny deep rubbing noise they make), wont seem to grab as hard etc.
there is no point replacing the clutch because you hit xx,xxx miles. run it till its crap.
-Joe
Kamin is offline   Reply With Quote
Old 01-31-2003, 07:21 AM   #3
mrmephistopheles
mrmephistopheles's Avatar
Seen an 02 Frontier clutch needing to be replaced at 20k miles.
How easy you are on the clutch will determine the lifespan of it.
If you shift smoothly and such it should last a long time. (150k+ miles)
Kevin
Old 01-31-2003, 10:12 AM   #4
tnord
tnord's Avatar
tnord is an unknown quantity at this point
pretty much any time you have the transmission out it's a good idea to just go ahead and replace it. within reason of course, if you still have 50% or more material left, leave it. when my tranny was out at 50k miles they said i had between 1/3 and 1/2 of the material left, so i went ahead and replaced it.
tnord is offline   Reply With Quote
Old 01-31-2003, 10:21 AM   #5
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
The stock clutch isn't too expensive anyways... about a little over $100 IIRC. It's when you go with a performance clutch that you wait to the last second to replace it.
AceInHole is offline   Reply With Quote
Old 01-31-2003, 10:43 AM   #6
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
To my knowledge, the previous owner didn't replace the clutch during the 127K miles she put on it. I also have not changed the clutch since I got it...which means it has an amazing 186K miles on it!
LanceS13 is offline   Reply With Quote
