11-15-2008, 11:21 PM | #1 |
My Coupe build....The End Result...
I don't think I ever posted anything here about my build that I completed in August.
I bought the car last January....ripped it apart...and built it from the ground up. EVERYTHING on the car was done by me. And I mean EVERYTHING. I painted it, did all the fab work, all the mechanical, even tuned it. I'm pretty happy with the way it turned out. This is what it looked like the day I bought it. Drove it 900miles from Philadelphia to Western Michigan without a single hickup. Then it went into work with me. I worked at AllSpeed Performance in Muskegon MI. On my lift waiting the tear down... Interior gutted for roll bar Picked up a Silvia front from EliteJDM The beginning of my Defi collection Rollbar allmost finished. I waited untill the seat was mounted to figure out how I wanted the harness bar I cut out the stupid hump on the drivers side floor board. I'm 6'1 and it was a crunch for me in a racing seat and I really wanted more head room for when I was in the car with a helmet on. The main hoop of the roll bar really took up alot of space. Before All material removed New floorboard welded in place Next up was doing the body work on the front end. It wasn't too bad but having never done bodywork, I had to learn on this car I painted the engine bay first. I was pretty scared that I'd have major problems with dirt and grease so I did it seperatly than the rest of the car. I actually had no problems at all. It came out beautifull.. Rest of the car in primer. After MANY MANY hours of painfull bodywork. The end result... I also picked up a set of used Gramlights. This is what they looked like on when I got them... But I had a ton of extra paint so pearl white gramlights sounded sooooooo gangsta Looks MUCH better Now for the engine... I dont have too many pics of the internal work. I did all the headwork late one night and I was the only one at the shop and since I'm an idiot....I forgot to take pics. But....on with the goodies... Engine in...I did this ALONE! NEVER try to drop in an SR by yourself! It sucked big time But it got in there and I quickly started bolting everything in.. Installed the oil cooler set-up as well. Tomei oil block adapter, remote mount oil filter pedistal, Setrap oil cooler, and earls pro-lite -10an lines... AN vacum lines under manifold The first start-up. New Seat installed... Siebon carbon fiber hood installed. I DA'd off the crappy clear coat it comes with and sprayed 6 coats of good clear with a little bit of pearl in it as well. Breathing fresh air for the first time!!! And heres all the fliks of the finished product. I still have a little I want to do. OEM Aero side skirts, either an Aero lip or pignose, and a differnt steering wheel with a quick release... A complete List of Mods done... Engine Redtop Sr20 Stock Bottom End Fully Port and polished head Apexi Double Valve Springs Apexi Retainers Ferrea 6000 Series Valves Tomei 256/256 Cams HKS 1.2mm HeadGasket Tomei Rocker Arm Stoppers HKS GT Tubular Manifold HKS GT28RS .64 A/R -4an Oil Feed Lines and Coolant Feed and Return Lines -10an Oil Return Line Custom 3in 304SS Downpipe Nismo Transmission Mount Nismo Engine Mounts Greddy Oil Pan Greddy Intake Manifold HKS SSQV Custom Polished Aluminum 2.5/3in Intercooler Pipping Bulleseye Peroformance 700hp FMIC Koyo Radiator FAL Dual 12'' Electric Fans SAMCO Rad Hoses S14 Water Pump HKS O2 Housing Apexi GT Spec Exhaust x/resonator delete Custom Catch Can Set-Up Using -10an Lines Circuit Sports OverFlow Tank Apexi Power Intake Z32 MAF Custom 3in Polished Aluminum Turbo Intake Pipe Nismo Thermostat Nismo RAD Cap Power Enterprise Accessory Belts Custom -10AN Catch Can System Custom Oil Cooler Kit -Tomei Billet Oil Block Adapter -Custom Made Billet Aluminum oil Filter Relocation pedistal -Setrab 32 Row Oil cooler -10an Earls Pro-Lite Oil Lines Drivetrain Stock SR20 GearBox Nismo Clutch Arm Pivot Nismo Slave Cylinder Blitz Active Single Disk Clutch Clutch Dampener removed Silvia VLSD Silvia 5 bolt Axels JDM Silvia 4.32 Rear End Silvia Driveshaft Ichiba 5 Lug Hubs Z32 4 Piston Calipers Z32 280x30mm Rotors Project Mu Brake Pads Brembo Sport Drilled and Slotted Rotors GoodRidge Stainless Steel Lines EMS and Fuel System Apexi Power Excel Stand Alone EMS Apexi Power Commander SARD 850cc Injectors Tomei Fuel Pump Tomei Fuel Rail Fitting Aeromotive Adjustable FPR -6N Fuel Lines Chassis Painted PPG Ferrari Pearl White Custom RollBar Integrated Into Rear Strut Towers and Floor Boards Frame Rails Fully Stitch Welded DriverSide Floorboard Lowered 3-4in to Increase Head Room OEM Silvia K's Front End Conversion Tanabe Sustec F&R Tower Bars Suspension Tein HE Coilovers Full SPL suspension arm kit---comming very soon Tein Tention Rods Interior Bride Zeta III Driver Bucket seat Sparco Steering Wheel Custom Made SuperLow Seat Rail Black Interior Conversion Defi BF Gauges --Boost --EGT --Oil Pres --Oil Temp --Water Temp --Fuel Pressure AEM WideBand UEGO Gauge Nismo Shift Knob GReddy ProfecB Spec-II Boost Controller Wheels Volk 57 Gramlights 18x8.5 19x9.5 Custom Painted Pearl White Toyo T1R 245/35 275/35 I plan on having a nice photoshoot done soon. I'll post up new pics when I do. |
11-16-2008, 01:37 AM | #8 |
Great looking car. Was planning on the same color for my S14. And holy shit those white gram lights are sexy as hell!
11-16-2008, 01:55 AM | #11 |
so you custom fabbed the part that your oil filter screws onto? damn
i was just going to ask you what you used for that because i'm building a custom oil cooler setup and i plan on using the tomei block as well. |
11-16-2008, 02:00 AM | #12 |
CLEAN JOB MAN!!.... Im Jealose...... But to be a critique..... Gotta talk to you about your gages on ur dash........ -.-.. Dont look to good
Pissing Off Daily Commuters |
11-16-2008, 02:53 AM | #14 |
The Architect.
Trader Rating: (392)
Feedback Score: 392 reviews
Holy shit is that nice.
11-16-2008, 10:32 AM | #19 |
nice car know ya from TST haha
11-16-2008, 11:18 AM | #22 |
Clean, simple, and has decent power to back it up.
Props X100000000000000000000
"So here I am, right back at it again, just like I've always been" |
11-16-2008, 11:31 AM | #23 |
congrats on the build. Great attention to detail (especially by taking the time to take off ALL the moldings during paint prep. I hate seeing painted window molding.)
As far as the body work, it seems pretty good. When you get a chance though, reinstall the bumper support, or make a support so the bumper doesn't sag. Yes, I realize with the front mount, you need to cut out about 80% of that sucker, but at this point its not about absorbing energy during a front end collision.
11-16-2008, 11:39 AM | #24 |
Location: Amerika24 alabama: Where if your not first..... your last
I love the simplicity and cleanliness of this car. Its highly modded yet almost looks factory. Nice work
11-16-2008, 11:48 AM | #25 |
Not a fan of same colored wheels. No contrast at all, looks funny.
Also, with everything out of the car, why didn't you stitch weld the bay/interior?
Blow me, bitches. |
11-16-2008, 11:57 AM | #26 |
do you plan on staying with dual projectors and ugly grill?
the same color wheels do look interesting, but i think it can work. done with criticizing. your car is awesome |
11-16-2008, 12:13 PM | #27 |
Very nice and simple, I plan on doing something very similar to my hatch, AND I FUCKEN LOVE THE ROLL BAR. But I got to ask though how were you on time: how long did it take.
OH yhea fuck the fags that were talking shit with there criticism, like to see them do anything near of a project you did, and not fuck it up. -to each his own.
IG Holy_khal Last edited by deadghost; 11-16-2008 at 12:58 PM.. |
11-16-2008, 12:17 PM | #28 |
All that effort on the engine, and you put the OE shitass oil pressure switch back on. -1. It will leak and make a mess out of the nice underhood paint. Otherwise it's an A+.
