Old 11-18-2008, 12:18 AM   #1
tdawg88
tdawg88 can only hope to improve
s13 All of a sudden no start!
Ok so the car has been working and starting flawlessly. I wired my type x tails to both turn on correctly and the car still started after that. Went to the store, came back home, and bammmm 1/2 hour later I wanted to go out and no start.
There is no power going to the solenoid because nothing happens. No clicking and certainly no crancking.
I assumed that it may have been due to the immobilizer and so I removed it. I plugged in the starter lines back together and still nothing.
I dont want to splice anything else so Id like to know. Is there a way to go direct and skip any specific process to start the car?
Or if anyone has any advice I would appreciate it. Thanks
tdawg88 is offline   Reply With Quote
Old 11-18-2008, 12:21 AM   #2
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
Check your fuses, the ones located under the hood on the passenger side. Check if any of the fuses are blown. I had a similar issue happen about 2 weeks ago and I had a blown fuse, it was a 30A fuse iirc. A green boxed one. If its blown you'll be able to see it because the little metal strip in the fuse we be broken apart.
duffman1278 is offline   Reply With Quote
Old 11-18-2008, 12:47 AM   #3
tdawg88
Yea i checked the fuses and that 30 amp fuse is still good. I noticed that when I turn the key the cluster just blinks or fades a little. But no crank or click.
Old 11-18-2008, 12:48 AM   #4
bloodie73
bloodie73's Avatar
bloodie73 is a jewel in the roughbloodie73 is a jewel in the roughbloodie73 is a jewel in the roughbloodie73 is a jewel in the roughbloodie73 is a jewel in the roughbloodie73 is a jewel in the roughbloodie73 is a jewel in the roughbloodie73 is a jewel in the rough
did you try and....jump start it?
bloodie73 is offline   Reply With Quote
Old 11-18-2008, 12:49 AM   #5
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
bad ignition relay
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-18-2008, 12:51 AM   #6
tdawg88
Well I push started it and it ran no problem. So thats when I figured it was the immobilizer. But I removed it and Im not certain if it could be the relay switch as I hear that click.
But I dont hear the solenoid clicking. Sorry I didnt mention that btw.
Old 11-18-2008, 01:54 PM   #7
riceman
riceman is an unknown quantity at this point
you and i are having the same problem. i was thinking that it may be a bad ground or the solenoid is dead.
riceman is offline   Reply With Quote
Old 11-18-2008, 02:13 PM   #8
zaquanh
zaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura about
my does nothing when i turn the key , but it will let me kick start it , so i juss wired in a start button
zaquanh is offline   Reply With Quote
Old 11-18-2008, 02:44 PM   #9
riceman
lmao i was going to do the same thing but i decided ill do that as a last resort kind of thing. Anyways i found this on the forums and i think it could help. i forgot who said it but check all the ground wires from the battery and from relay box (passenger side, or both idk)to make sure they are all secure. if i have time im going to give this a shot when i get home from work.
oh heres a link to the thread if you didnt see it already:http://zilvia.net/f/tech-talk/224248...oblem-wtf.html
Old 11-26-2008, 08:35 AM   #10
riceman
http://www.courtesyparts.com/betasit...-p-228496.html
ok i figured out why it doesnt start. if you click on the url i posted above click on the middle pic near the bottom. there is a flat pin that you clip in along with the power. i believe that tells the starter to turn on but for some reason its not getting the signal. so i rigged a switch to it just for temporary use so i can easily move it when i need to. so how can i get that thing back in working order.
thanks in advance
