Old 11-19-2008, 07:15 PM   #1
kouki_matt
kouki_matt is an unknown quantity at this point
starter relay
i got my 95 s14 from some guy and he ghetto rigged the shit out of it and i cant find the starter relay so if anyone can help my out that would be great ive looked on here and its all about the 13's relays thanks pm me thanks and i forgot to say it starts fine in the morning when its cold out but during the day when its hot out i have to push start it thanks for everyones input
Last edited by kouki_matt; 11-19-2008 at 10:20 PM.. Reason: forgot to add something
kouki_matt is offline   Reply With Quote
Old 11-19-2008, 07:17 PM   #2
!Zar!
!Zar!'s Avatar
On the s14 it's call the Clutch interlock Relay (ASCD).
It's located in the passenger side fuse box.
Old 11-19-2008, 08:21 PM   #3
g6civcx
g6civcx's Avatar
Incorrect.
There are several components being confused together:
1. When you turn the key to ST, power is supplied to the starter solenoid. Curent is then pulled to the relay via the thick starter wire. The solenoid is a form of "relay".
2. There is a switch located the bottom of the clutch pedal's travel. When you floor the clutch pedal, the switch is activated. This switch controls the cluth interlock relay. Without depressing the clutch all the way out, power will not be allowed to reach the starter solenoid whe you hit the key to ST.
3. There is a switch located at the top of the clutch pedal's travel for the Automatic Speed Control Device (ASCD). When you tap the clutch pedal, this switch cancels cruise control.
As per the original question, my recommendation is to find an FSM for your year S14 and go through the wiring diagrams and check every single wire for the starter system.
Old 11-19-2008, 09:23 PM   #4
kouki_matt
i tried everywhere for the book and no one has it not even nissan but thanks im going to try the asdc relay and if thats not it ill let you all know thnks
Old 11-19-2008, 09:51 PM   #5
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
Index of /FSM/240sx/1995
this is the 95 service manual. give me a second and ill remember what section describes the location of relays.
surreybc is offline   Reply With Quote
Old 11-19-2008, 09:55 PM   #6
projectRDM
projectRDM's Avatar
Originally Posted by g6civcx View Post
Incorrect.
Close. The starter relay is indeed called the clutch interlock relay on S14s, located in the main fusebox. Though it has nothing to with the ASCD, that's where it is. The starter signal goes to it, and once energized goes back out, the relay is energized by a ground trigger from the clutch switch. Same principle as the S13 setup but with a smaller relay mounted in the box instead of hanging on the fender apron.
FORMERLY R240NA
Old 11-19-2008, 09:56 PM   #7
surreybc
section EL page 190. relay is in the fuse box by battery. I will supply pic in next minute.
Old 11-19-2008, 10:01 PM   #8
surreybc
Old 11-20-2008, 06:14 AM   #9
g6civcx
g6civcx's Avatar
I thought that's what I said. When you floor the clutch pedal, the clutch interlock relay is activated and allows current to go from the ST pin on the ignition switch to the starter solenoid.
S14s don't have the blue relay by the front right fender. Look in the FSM for the location.
Old 11-23-2008, 07:54 PM   #10
kouki_matt
anymore ideas i changed the relay and it starts better at night but idk still ? help
Old 11-24-2008, 11:41 AM   #11
surreybc
have you hit the starter and or the solenoid when it doesnt start? how is your battery and alternator?
Old 11-24-2008, 12:26 PM   #12
!Zar!
!Zar!'s Avatar
So... amirite?
