Old 11-24-2008, 12:34 AM   #1
240sxrb25
240sxrb25 is an unknown quantity at this point
ka24e bad throttle response, good idle
i just ran some seafoam through the small vacuum line that goes to the throttle body.
luckily it did get rid of my lifter ticking, but it seems that my throttle response isnt good. at about 1500 it accel. and decc. smoothly, but anything above sucks. i will ease into the gas and get nothing. i give it more gas and nothing, then a little more and it jerks forward as if i immediately floored it. then i back off slowly and it acts like i completely let off the gas in a hurry. driving it throws me back and forworth and its really annoying.
any ideas?
240sxrb25 is offline   Reply With Quote
Old 11-24-2008, 02:20 AM   #2
chrissyPOO
chrissyPOO is an unknown quantity at this point
Try checking your o2 sensor, I've heard seafoam can be hash on your o2 sensor.
chrissyPOO is offline   Reply With Quote
Old 11-24-2008, 11:58 AM   #3
aziankingz
aziankingz's Avatar
Trader Rating: (28)
aziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really niceaziankingz is just really nice
Feedback Score: 28 reviews
your cars going to run crappy after putting in seafoam...did you make sure you idled and/or drove hard enough to get out all the seafoam? just drive around for a bit..it should get better.. if not check your injectors
aziankingz is offline   Reply With Quote
Old 11-24-2008, 12:03 PM   #4
nieko
nieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfectionnieko is close to perfection
did it do this before seafoam too?
kinda sounds like timing with all the jerking and stuff when letting off and pushing the gas
nieko is offline   Reply With Quote
Old 11-24-2008, 03:30 PM   #5
240sxrb25
this doesnt pertain to what i did with seafoam, but i checked codes and for some reason my tps was out of adjustment
Old 11-24-2008, 06:08 PM   #6
nieko
get a voltmeter. set it at .45 volts
