Old 11-24-2008, 05:03 PM   #1
Mr.s13r
Mr.s13r is an unknown quantity at this point
venting engine bay
Do you guys do this?
Technical Articles: Increasing Engine Bay Venting
Is it really that beneficial like the thread poster said? What are the cons to this?
thanks
Mr.s13r is offline   Reply With Quote
Old 11-24-2008, 05:04 PM   #2
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
It looks ugly.
Old 11-24-2008, 05:08 PM   #3
slider2828
slider2828's Avatar
I do.... SRs run kinda hot.... I vent it cause of the turbo timer and stuff....
Turn and Burn!
Old 11-24-2008, 05:10 PM   #4
S14DB
AFC #1
S14DB's Avatar
It only works standing still. At speed it increases under hood pressure. Possibly reducing flow over the radiator.
Old 11-24-2008, 05:11 PM   #5
!Zar!
!Zar!'s Avatar
Ding ding ding.
In other news.
Why does it say, "install" takes an hr?
They got to be kidding.
Old 11-24-2008, 05:12 PM   #6
Sileighty_85
Sileighty_85's Avatar
Its the poor mans hood vent
just buy a vented hood not to expensive from here
CW Flared Hood | S13 [H234] - $299.00 : Chaser Aerodynamics, LLC
I bought mine from these guys, products not bad but their shipping methood sucks
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 11-24-2008, 05:14 PM   #7
!Zar!
!Zar!'s Avatar
Or just make a vented hood out of an oem one.
Old 11-24-2008, 05:16 PM   #8
slider2828
slider2828's Avatar
It would not reduce radiator flow if you have a top panel, but if that at speeds... Yup hence turbo timer...
Turn and Burn!
Old 11-24-2008, 05:19 PM   #9
MetricHotrods.com
MetricHotrods.com is an unknown quantity at this point
food for thought.
someone on the british GTR forum got scientific about hood venting. basically they came to the conclusion that any hood venting takes heat from down low (downpipe ect) and pulls it up high, past your intake manifold and intake. heat that, if your hood was standard, would get sucked out underneath your car. the guy hooked up a couple temp sensors and everything.
MetricHotrods.com is offline   Reply With Quote
Old 11-24-2008, 05:41 PM   #10
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Originally Posted by MetricHotrods.com View Post
food for thought.
Heat rises dude, the top of the engine bay will always be hotter than the bottom. The people on that GTR forum are retards.
Old 11-24-2008, 05:46 PM   #11
MetricHotrods.com
heat doesnt rise when a car is doing highway speeds and its being sucked out from underneath.
Old 11-24-2008, 09:44 PM   #12
racepar1
racepar1's Avatar
Heat still gets trapped at the top of the engine bay as there is very little airflow up there. I would LOVE to see some actual proof that the air is being actively sucked out of the engine bay as well.
Old 11-24-2008, 10:04 PM   #13
S14DB
AFC #1
S14DB's Avatar
There is negative pressure under the car that sucks the air down out of the engine bay. Why the stock areo tray is designed like it is.
There is positive pressure in front of the windshield. When you jack up the hood in the rear it lets that air into the engine bay. Staling out the air that was being sucked though the radiator. Easier to go from an open high pressure area then though a screen.
The Hoods with vents work cause they are before the bubble in front of the windshield and use the suction of the air flowing over the hood to suck air out.
Muscle cars from have the cowl induction hood to use the high pressure to ram air into the intake. Not for cooling or venting.
Old 11-24-2008, 05:30 PM   #14
tckracker
tckracker's Avatar
tckracker will become famous soon enoughtckracker will become famous soon enoughtckracker will become famous soon enough
I would say just don't rearend anyone because that hood WILL shear those bolts because of the the increased moment force and come visit your face in the interior. I would try not to disable safety in my car. Just my .02
-Shaun
tckracker is offline   Reply With Quote
Old 11-24-2008, 05:39 PM   #15
racepar1
racepar1's Avatar
That is NOT the way to vent an engine bay, The area at the bottom of the front windshield is a high pressure area. By lifting the back of the hood like that you are letting more air into the engine bay from the back. That by itself may be ebneficial, but more air in the engine bay means more pressure in the engine bay. That reduces flow across the radiator, which is very, very bad. To properly vent an engine bay you want to increase the airflow through the engine bay, which means to reduce the pressure inside the engine bay. Lifting the back of the hood does exactly the opposite of what you want. The above principals are the reasons why cowl induction hoods were so popular and effective. Look at nascars, they have cowl induction because the pressure at the bottom of the windshield has a ram air effect. The LAST thing you want is to ram air into your engine bay from the back.
Old 11-24-2008, 05:41 PM   #16
trsilvias13
only other benefit is for hood clearance where some motor or part of it sticks up
trsilvias13 is offline   Reply With Quote
Old 11-24-2008, 05:42 PM   #17
zaquanh
zaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura aboutzaquanh has a spectacular aura about
super old topic , search
juss get an actual vented hood
zaquanh is offline   Reply With Quote
Old 11-24-2008, 06:47 PM   #18
irax
irax's Avatar
thanks
i've done this with my s13 and I noticed a difference in all around temps, especially driving at night. 2 inch is way to crazy, honestly 7/8 of an inch was enough to make a difference.
irax is offline   Reply With Quote
Old 11-24-2008, 06:55 PM   #19
projectRDM
projectRDM's Avatar
Holy fuck, is it 1967 all over again? Hot rod guys did this shit even before fuel injection was mainstream.
FORMERLY R240NA
Old 11-24-2008, 07:19 PM   #20
MetricHotrods.com
rdm, its been established that everything in the import scene is just something an aircooled VW person did 30 yrs ago. big deal. stance, camber, offset, fender flares, wiretucks, paint, engine swap ect ect ect...
Old 11-25-2008, 12:44 AM   #21
Mr.s13r
Wow damn all of these are very informative well then i'll not go with the spacers but then what you guys think about this but for the 180sx:
http://us.st12.yimg.com/us.st.yimg.c..._2030_52139516
Old 11-25-2008, 06:49 AM   #22
g6civcx
g6civcx's Avatar
I'll try to flashback to my motorsports engineering classes from 15 years go.
I realised from the beginning that aero is pretty much pure speculation. You either have to rent a full scale wind tunnel to the tune of $10k per hour, rent a smaller wind tunnel and build a scale model, or at least do computer simulation.
Everything else is pure speculation. That's why I stuck with digital control systems.
Trying to move air molecules is like trying to herd a group of very antisocial and lazy people. When you group them together, they try to spread apart as much as possible via the path of least resistance.
Air will try to move from areas of crowding (high pressure) to areas with open space (low pressure).
When a car is traveling through air, the highest areas of pressure are 1) the leading edge of the bumper, and 2) the base of the windshield.
Any time you try to separate air layers and puch a hole through the air you will get resitance.
Airplanes try to make the fuselage as pointed as possible to reduce drag. Also, "sports" cars have steeply raked windshields to reduce drag as well.
Generally, in order for air to move through the radiator fins, you need to create an incentive by putting a low pressure area directly behind the radiator. You can do this with a fan, and/or by blocking all other paths of travel with cooling panels.
Once air is in the engine bay, it needs to leave. You can use undertrays to create a venturi effect and force the air to travel between the engine and the undertray. This can also create front end lift as the air travelling below the car lifts the front end.
The other area is the base of the windshield. If you cracked the hood open, the area under the hood near the valve cover would have low pressure. The air would go from the high pressure area of the base of the windshield into the valve cover area. Then where would it go?
If you have your intake where the valve cover area is, which is where Chevy small blocks do, you can take advantage of the ram air effect and suck in more air into the carb. Otherwise air would stall around the underhood area and run into each other.
Again, these are just generalizations, and it depends on the specific design of the car. Nobody is right and nobody is wrong. It's just opinions.
