Old 11-25-2008, 08:19 AM   #1
redpotatoes
redpotatoes's Avatar
redpotatoes is on a distinguished road
KA-T Setup Dyno Session
Went on the dyno to have my car finished. I am happy with the results. AFR was at 11.x~12 and boost was set at 10psi (was running 9.X on the dyno).
My current setup is:
97 Engine with a 95 intake
T28BB Turbo (Rebuilt with a ported wastegate)
370cc injectors (DeatschWerks rebuilt and tested)
N60 Maf
Bottom mount manifold
Turbo elbow
Custom 3" downpipe
3" testpipe
5 zigen fireball cat back ~2.5" (60.5mm)
Custom 2.5" Intercooler piping
FMIC 28x6x2.5
OEM Nissan gaskets
NTK 02 sensor new
BKR6E spark plugs
OEM Fuel filter
Walbro 255 fuel pump
JGS Vacuum block
Greddy BOV type rs
Greddy Profec-b spec II boost controller
S13 ECU (Almasi tuning)
Fidanza flywheel
Bully performance Stage 4 clutch kit
Optima redtop battery relocated in the trunk
Dyno session took place on a dynapack. Here it is !
redpotatoes is offline   Reply With Quote
Old 11-25-2008, 10:02 AM   #2
slider2828
slider2828's Avatar
Nice, what type of Octane are you using up there? I would also change the plugs to something colder like a BK7 or 8 RE..... 6 runs pretty hot. BUt nice numbers....
Turn and Burn!
Old 11-25-2008, 10:08 AM   #3
redpotatoes
The car is tuned with 91. I could have tuned the car with 94 but went 91 for it's availability in every gas station and because of the gas price these days. As for the plugs, BKR6E work perfectly with my setup for now, might go colder next time I change them.
Old 11-25-2008, 10:13 AM   #4
ChiSleepyEyes
ChiSleepyEyes's Avatar
ChiSleepyEyes is an unknown quantity at this point
Send a message via AIM to ChiSleepyEyes
gas prices?? havent they gone down in canada? they are 1.84$ here in chicago?!?
ChiSleepyEyes is offline   Reply With Quote
Old 11-25-2008, 10:15 AM   #5
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
That looks like fun right there.
anything done to the motor?
15lbs of boost would be sweet.
Old 11-25-2008, 11:20 AM   #6
redpotatoes
Yes it did go down in the past weeks but it's only a matter of time before it goes up again...
Nothing has been done to the engine. I use too have 2x248" cams from a 91 but I removed them. I could boost to 15lbs but it wouldn't be as safe/reliable as now, I would also need to upgrade my injectors to boost at that level. This setup is safe/reliable at 10psi all day long so I don't plan to boost more than that for now. I have 2 spare engines in the garage. I might think about more boost eventually
Originally Posted by slider2828 View Post
Secondly, are you running any timing retard or running less timing advance, (meaning closer to tdc)?
Today 12:15 PM
I don't know what the timing was adjusted to, everything was tuned on the dyno by my tuner. He started with timing retarded and worked is way up from there I think.
Old 11-25-2008, 10:29 AM   #7
slider2828
slider2828's Avatar
I have the same philosophy in tuning, but I run a built motor on 93.5. In the mid range in my case, would run closer to 13 afr and rich to 11.5 till red line gradually? I don't have a knock sensor so I am trying to figure this out. Secondly, are you running any timing retard or running less timing advance, (meaning closer to tdc)?
Turn and Burn!
Old 11-25-2008, 11:27 AM   #8
NemeGuero
No more nissan.
NemeGuero's Avatar
Whats up redpotatoes!
You should put some bigger injectors on.
Old 11-25-2008, 11:33 AM   #9
redpotatoes
Hey! I know eventually I will but have a look at this, not to bad for some 370cc.
Deatsch Werks complete cleanup and report (basic service)
370cc Nissan SR20DET Injectors
Static flow
Injector# - cc/min - lbs/hr
1 - 404 - 38.4
2 - 408 - 38.9
3 - 408 - 38.9
4 - 406 - 38.7
System Overview
cc/min - lbs/hr
Total System 1626 - 154.9
Min. Flow 404 - 38.4
Max Flow 408 - 38.9
Avg Flow 407 - 38.7
% Balanced 98.8%
% Difference 1.2%
Old 11-25-2008, 11:48 AM   #10
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
that's a nice torque curve..haha
R@ddy is offline   Reply With Quote
Old 11-25-2008, 11:58 AM   #11
Ninjabread
Ninjabread's Avatar
I like the way you spell your name, same as me. Good ole frenchies
Holy tq curve btw! haha
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 11-25-2008, 12:00 PM   #12
redpotatoes
Only 1 "T"
Old 11-25-2008, 12:00 PM   #13
gunluvS14
gunluvS14's Avatar
gunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura aboutgunluvS14 has a spectacular aura about
250 ft-lb of torque @ 2800rpm is pretty good
http://www.zilvia.net/f/image.php?type=sigpic&userid=45706&dateline=118722  3315
gunluvS14 is offline   Reply With Quote
