Old 11-25-2008, 01:21 PM   #1
aurora
aurora is an unknown quantity at this point
running better with maf unplugged?
My sohc 240 hasnt been undrivable for over a month now, and ive been trying to figure out wats wrong, but i cant figure it out.
With the MAF plugged in, my car starts just fine. The car doesnt idle since the revs drop down soon after the car starts. If i press down the throttle too fast, the car instantly dies. If i ease the throttle, i can keep the revs up high enough that the car doesnt die. However, once i hit 2000rpm, the car instantly dies.
With the MAF unplugged, the car idles just fine. I can rev the engine fine as well. However, it bogs alittle after 2000rpm. Ive also succeeded in driving short distances
Ive replaced the coolant temp sensor, ignition coil, sparkplugs, distributor rotor and cap, injectors, injector connectors.
Im guessing i need to replace the MAF, but after searching, it seems like thats its never really the problem.
Can you guys help me out?
aurora is offline   Reply With Quote
Old 11-25-2008, 01:42 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
You know I am having similar problems right now so I would really like to see some good answers and maybe we can both fix our cars
Old 11-25-2008, 01:49 PM   #3
!Zar!
!Zar!'s Avatar
Sounds like you need a new maf.
Either that or you have an air leak.
If you are using the stock intake, cracks normally develop on the accordion part near the throttle body. That would allow extra air in that hasn't been meetered.
Old 11-25-2008, 02:04 PM   #4
s13 @ fullboost
ooooo Good reply zar you always help out I actually think that might be it in my case
Old 11-25-2008, 10:59 PM   #5
aurora
i have an injen intake so thats not the case with me
i also checked for vacuum leaks and i even replaced some vacuum lines as a precaution
i want to believe the problem is the maf, but i guess i want a second opinion before i buy one...especially cause i already spent a good amount of money for parts that didnt need to be replaced
Old 11-25-2008, 11:04 PM   #6
!Zar!
!Zar!'s Avatar
Well if it makes you feel better, I went through the same thing and it ended up being the maf.
Old 11-25-2008, 11:14 PM   #7
Rapier46
Rapier46's Avatar
Rapier46 is an unknown quantity at this point
Send a message via AIM to Rapier46
Mine did this at one time. I had an intercooler pipe off. Non turbo though? Hm.
Rapier46 is offline   Reply With Quote
Old 11-26-2008, 01:14 AM   #8
mobilesuit818
mobilesuit818's Avatar
mobilesuit818 is an unknown quantity at this point
If you have a friend that has the same car, swaps MAF's out. that should do the trick.
If that doesnt rule it out, then it maybe a fuel pump issue.
I had the same issues years ago on my rolla, and it turned out to be a broken ground wire in the engine bay.
Hope that helps.
Quality is not expensive, its priceless.
mobilesuit818 is offline   Reply With Quote
Old 11-26-2008, 03:06 AM   #9
VQMaxFan
VQMaxFan's Avatar
VQMaxFan is on a distinguished road
Maf is bad or possibly backwards.
VQMaxFan is offline   Reply With Quote
Old 11-26-2008, 03:26 AM   #10
punkrico
punkrico is on the path to ruinpunkrico is on the path to ruin
id say MAF too. When you unplug it the car goes into safe mode thats y it runs better
punkrico is offline   Reply With Quote
